m&p specials
Moderator: VTRDark
macdee
m&p specials
Post by macdee »
Re: m&p specials
Nice one Macdee :thumbup:
Are heated grips noticably fatter than Renthals for example?
leevtr
Re: m&p specials
Post by leevtr »
Had a look at this and nearly bought a loading ramp. Decided to have a quick look on the bay and found one for £25, happy days !!
bigtwinthing
Re: m&p specials
Post by bigtwinthing »
leevtr wrote:Had a look at this and nearly bought a loading ramp. Decided to have a quick look on the bay and found one for £25, happy days !!
Thats expensive for a scaffold plank!!!
ging500
Re: m&p specials
Post by ging500 »
My next purchase is going to be an abba stand!!
Re: m&p specials
Jamoi wrote:Nice one Macdee :thumbup:
yes I think they are and that is why I never had them fitted to my bikes................till I discovered the Symtec heating element that you fit to the bars then put your renthals back on top of them. best for both worlds now
Re: m&p specials
Ahh nice one Al, were they simple to fit? Nice and warm? I'll have to look into them :thumbup:
Re: m&p specials
yes simple to fit, the wiring and relays are the main pain, and they are the same as fitting any heated grips.
yes nice and toasty, but 2 comments.
1) only 2 settings so not as fine control as others, so with wet summer gloves setting 2 can get too hot and you can burn your palms as the heat transfer is helped by the water!
2) even though they design the element to be different power to compensate for the different heat conduction of the plastic twist grip vs the bare ally handlebar, it was still hotter on the throttle side than the clutch side. So to fix that I took the element off and fitted a heatshrink tube over the ally bar and refitted the element and grip.........doing this after you have fitted it is a real pain, so do the adhesive coated heatshrink before you do the first fitting.
Re: m&p specials
Sweet, thanks for the info :) good tip with the heatshrink on the left bar.
Are these a good price? http://pages.ebay.com/link/?nav=item.vi ... 0286947416
Re: m&p specials
I am sure I only paid £48, but it was from the same place so looks like the price has gone up
Re: m&p specials
Just my luck! :(
I'll pop it on the watch list and hopefully purchase one around February.
Cheers :thumbup:
Re: m&p specials
AMCQ46 wrote:yes simple to fit, the wiring and relays are the main pain, and they are the same as fitting any heated grips.
Can you not just route the exhaust pipe from the front cylinder up in front of the headstock, through a splitter/reducer and exit out through the clipons?
That'd work, no trouble, definitely, that.
"you were only supposed to blow the bloody bars off......"
Re: m&p specials
Be easier to run the coolant up into the bars :-)
Re: m&p specials
Or a nice heated, tartan blanky ;)
Re: m&p specials
lloydie wrote:Be easier to run the coolant up into the bars :-)
Oh, and all the coolant running out of the bar ends is going to be a good thing?
Think it through, Lloydie...........Tch.
