Battery cca
- denisblackvtr
Battery cca
Happy new year to everyone, I haven't been on here for a while due to personal probs. Anyway I will be putting my baby back on the road this year and I was wondering if anybody knows what the cca of a standard battery is? Thanks in advance. Den.
GAS GRASS OR ASS NOBODY RIDES FREE
Re: Battey cca
no I don't. mind you I don't know what CCA stands for either?
what is it?
what is it?
Re: Battey cca
Thank god someone else don't know , thought it was only me . Welcome back fellow northernerlumpyv wrote:no I don't. mind you I don't know what CCA stands for either?
what is it?
Re: Battey cca
CCA for a YTX12-BS is.......180A
- turbo_billy
Re: Battey cca
what is it?
Cold Cranking Amps (CCA)
CCA's are defined as the discharge loads measured in amps that a fully charged battery at 0 degrees F (-17.8 degrees C) can deliver for 30 seconds while maintaining the voltage above 7.2 volts.
Basically, the bigger the number, the longer the battery will keep the engine spinning over fast enough to aid easy starting.
- denisblackvtr
Re: Battey cca
Cheers Tattoo, is that the standard output coz i'm looking at replacing the battery with a higher cca but they seem expensive for just a few more amps.tattoo wrote:CCA for a YTX12-BS is.......180A
- denisblackvtr
Re: Battey cca
Cheers Watty, when I get my bike back on road perhaps we could meet up for coffee.Watty wrote:Thank god someone else don't know , thought it was only me . Welcome back fellow northernerlumpyv wrote:no I don't. mind you I don't know what CCA stands for either?
what is it?
Re: Battey cca
CCA- Cold Coffee Appointment?denisblackvtr wrote:Cheers Watty, when I get my bike back on road perhaps we could meet up for coffee.Watty wrote:Thank god someone else don't know , thought it was only me . Welcome back fellow northernerlumpyv wrote:no I don't. mind you I don't know what CCA stands for either?
what is it?
(just messing- it's as above, really)
Re: Battey cca
thank you perhaps I can put this in "what have you learned today" thread.turbo_billy wrote:lumpyv wrote:no I don't. mind you I don't know what CCA stands for either?
what is it?
btw , how long is a battery supposed to last? ive still got the one that was on it when I bought it 4 years and about 8,000 miles ago. I give it the trickle in the winter and the bike starts a treat all the while ? also had the old r/r fail in that period.
Re: Battey cca
That sounds good mate, just give me a shout .denisblackvtr wrote:Cheers Watty, when I get my bike back on road perhaps we could meet up for coffee.Watty wrote:Thank god someone else don't know , thought it was only me . Welcome back fellow northernerlumpyv wrote:no I don't. mind you I don't know what CCA stands for either?
what is it?
Re: Battery cca
Yep standard output according to the spec listing...as for a replacement,i went for the motorbatt..alittle more in price (although i got mine at half price),higher cranking amps and my bike hasn't failed to start even when the temps been in the minus numbers..the only downside i found is that the battery cover no longer fits...
