Removing a dent from tank
Tenesmus
Post by Tenesmus »
Spot the dent...
Is there any way of pushing it out? The paint is fine so I don't want to mess about too much from the outside. Is it possible to get something weirdly angled through the filler?
History: Honda C70, CG125, CX500, CB750F, VF750F, Suzuki GSX750, red Honda VTR1000F, Yamaha XV1100, Vmax, yellow VTR1000F.
2005 Rover 75 2.5 auto Connoisseur Tourer in British Racing Green
2016 Vauxhall Viva "Father Jack"
leevtr
Re: Removing a dent from tank
Post by leevtr »
Someone else might confirm this, but that looks like a compressor job. Either that or remove tank, empty, take out fuel sender unit and something blunt from the inside would be easier than from the filler hole. I'd try a piece if 2x1" timber cut square,( if it will fit ) with a heavy duty plastic bag wrapped round it in case of any splinters. Dont use anything remotely sharp.
E.Marquez
Post by E.Marquez »
DO you guys have paint-less dent repair blokes over there? On this side of the pond, Paint-less dent repair is the sh1t.... and a decent guy can fix that dent..
Marquez Motorcycle Services
Post event services
Total Rider
And advanced Rider training
gabi81
Post by gabi81 »
if its a diy solution you seek ...dont!!
you will crack the paint and respray is the solution ...there is a shop around here that specializes in this kind of work if you want i could ask how much it will cost to have it done
Wow!!! I'm impressed not seen that process done before. Looks like it needs some serious skill positioning and controlled force on the slide hammer.
[youtube][/youtube]
gabi81
Post by gabi81 »
Yes but the surface is much bigger and metal more flexible
there is a suction thing that works wonders on cars but our tanks are much sharper and thicker....
mattycoops43
Post by mattycoops43 »
Seen it done with a compressor with good results.
