fuel light
Re: fuel light
Going to brim mine and check sure its 120+ though
Re: fuel light
Fiero, I actually meant earth the wire that feeds the sender. Sorry.
Re: fuel light
hey mate could you please refer the below image and let me know what i should really do to make the reserve fuel indicator to work, thanks
Re: fuel light
Where you unplugged that from bridge across the two terminals with a piece of electrical wire, that should fool the bike into thinking its low on fuelfiero wrote:hey mate could you please refer the below image and let me know what i should really do to make the reserve fuel indicator to work, thanks
Re: fuel light
but mate i wanted to actually work, as one day i stopped in middle due to no fuelWatty wrote:fiero wrote:hey mate could you please refer the below image and let me know what i should really do to make the reserve fuel indicator to work, thanks
atleast if i make this working, i would get a warning saying its time for fuel
Re: fuel light
I was merely trying to eliminate an inoperative warning light mate! If the light works using the method shown then the next thing to check would be the tank senderfiero wrote:but mate i wanted to actually work, as one day i stopped in middle due to no fuelWatty wrote:fiero wrote:hey mate could you please refer the below image and let me know what i should really do to make the reserve fuel indicator to work, thanks
Re: fuel light
oki mate let me check this first and move to the sender.
thank you
thank you
Re: fuel light
Yes eliminate the light/instrument cluster first before replacing the sender unit. Disconnect the connector plug as Watty said and short the two wires together to see if the light comes on. There are some other tests you can do depending on the result. Have a look at section 19 in the Honda workshop manual.
You can download a PDF Honda workshop manual from the following:
http://www.vtr1000.org/phpBB3/viewtopic ... 31&t=18025
Re: fuel light
page 19-17 did give good enough amount of info, thanks Carl.cybercarl wrote:Yes eliminate the light/instrument cluster first before replacing the sender unit. Disconnect the connector plug as Watty said and short the two wires together to see if the light comes on. There are some other tests you can do depending on the result. Have a look at section 19 in the Honda workshop manual.
Re: fuel light
Did you get this sorted mate?fiero wrote:oki mate let me check this first and move to the sender.
thank you
Re: fuel light
sorry for the late reply, the light comes up on shorting the two wires.fiero wrote:page 19-17 did give good enough amount of info, thanks Carl.cybercarl wrote:Yes eliminate the light/instrument cluster first before replacing the sender unit. Disconnect the connector plug as Watty said and short the two wires together to see if the light comes on. There are some other tests you can do depending on the result. Have a look at section 19 in the Honda workshop manual.
now need to remove the tank and check the sender for any wire cut or loose connection.
