Virt
Post by Virt »
MacV2 wrote: thingy of undetermined sexual gender :lol: :lol: :lol:
Don't talk about my Jamie like that :twisted: :evil:
I didn't !
I wrote Jamie & Virt...Man & you know the rest you've been struggling with it for years now ever since that christening dress...
seb421
Post by seb421 »
Spent four hours cleaning it and going over the bike, removed about a hundred shards of glass from the rear tire, this is probably why it started to feel wombles the other week, I rode through a big car crash but didn't think to check the tires after
Sent from my GT-I9300 using Tapatalk
seb421
Post by seb421 »
Big clean on the bike ready for a ride tommorw :)
Cleaned and polished up reet good :thumbup:
missed a small bit of muck on the flap under the bottom triple clamp (yoke) - 5th picture down :evil:
Top Tip - don't try and blow dry your bike with a hair drier takes ages and its pants, best to buy a proper one or just stick to micofibre cloths to pat dry the wombles
Ckennedy
Post by Ckennedy »
Looks good Seb :thumbup: want to do mine? :lol: :roll:
bigtwinthing
Post by bigtwinthing »
bigtwinthing wrote:here,s mine ready to go on.
Could someone please tell me the 3 adjustable bits. I know the spring. But what does the remote bit adjust. What does the Grey wheel at the bottom adjust Thanks Paul. I know the bottom threads adjust the ride height.
Virt wrote:
Jamoi wrote: I'm a strange lad.
In other equally unnecessary news, the grass is green.
:lol: :thumbup:
Remote adjusts compression damping and bottom adjusts rebound damping :thumbup:
bigtwinthing
Ta so remote adjust how fast spring goes down and rebound how fast it comes back up??. Not sure yet where to put the actual spring. any advice.
bigtwinthing
Stripped out all the swinging arm, greased all the linkage and fitted the WP Shock, changed the oil and filter and a quick test ride even though it was hacking it down it felt so much better. I need to get the adjustments right along with the Rogered Forks.Took it for its MOT bloody advisory for "Noisy Exhaust" lol :lol:
bigtwinthing
lloydie wrote:
Jamoi wrote:Lloydie, what settings have you ended up with on your shock?
Stiff :lol: I have about 38mm sag but without riding it to test it it most likely change .
43mm for mine today!!!!
bigtwinthing wrote:Ta so remote adjust how fast spring goes down and rebound how fast it comes back up??. Not sure yet where to put the actual spring. any advice.
That's right mate. Bike needs 8mm static sag, then when suspension is pushed down rebound damping should be set to return as fast as possible but under control. As for compression damping Roger recommended my Penske be set at number 4 for road use and 6 for track use. Hope that helps but I'm sure there will be a link on the forum somewhere for more detailed explanation. :thumbup:
Took mine out for a ride and it feels so much better with the new wp shock fitted .
Just need to play with settings now
Ckennedy
Post by Ckennedy »
Glad to hear your enjoying the shock :thumbup: such a vast improvement over stock 8)
bigtwinthing
Ckennedy wrote:Glad to hear your enjoying the shock :thumbup: such a vast improvement over stock 8)
It is,it did feel a bit odd to start, felt higher up, but by 20 miles it was great, once id got used to it. I think the rebound is returning a bit slow though.overall very very happy with it. Now just a belly pan!!!!
