Ckennedy
Post by Ckennedy »
Least you enjoy it :thumbup: did the belly pan turn up OK?
mattycoops43
Post by mattycoops43 »
Spent a day in the mattshed stripping and cleaning the bits that are off the storm. Swinger rebuilt and greased, all the linkages are re greased (all moving smoothly so hadn't got too far). Undertray wd'd to death and looking all minty fresh again. Looking forward to bolting it all back together again.
Virt
Post by Virt »
Rode it to the first bike meet of the year! Wooo!
Front wheel would not stay down :twisted: :twisted:
Let a mate have a go on it, on the premises of he pays completely if anything happens. Came back and started begging for another go not 5 minutes later.. I think I found a convert :wink:
Got in from work and increased the seat foam and covered in Alacantra (faux suede), just need to spray it with some waterproofing ermm.. spray!
I've managed to get the overal seat around 1" higher and firmer, also built up the front section to stop ball squish :)
Well chuffed innit
seb421 wrote:Big clean on the bike ready for a ride tommorw :)
Cleaned and polished up reet good :thumbup:
missed a small bit of muck on the flap under the bottom triple clamp (yoke) - 5th picture down :evil:
Top Tip - don't try and blow dry your bike with a hair drier takes ages and its pants, best to buy a proper one or just stick to micofibre cloths to pat dry the fcuker
Looking well clean mate 8)
bigtwinthing
Post by bigtwinthing »
Ckennedy wrote:Least you enjoy it :thumbup: did the belly pan turn up OK?
not yet :Cry1: :Cry:
Ckennedy
Post by Ckennedy »
Text sent to you Paul with whats happened with parcel
bigtwinthing
Ckennedy wrote:Text sent to you Paul with whats happened with parcel
Ok Ta i can chase it on Monday.
seb421
Post by seb421 »
Jamoi wrote:Got in from work and increased the seat foam and covered in Alacantra (faux suede), just need to spray it with some waterproofing ermm.. spray!
Well chuffed innit
I like that I'm copying you!
Sent from my GT-I9300 using Tapatalk
Jscobey
Post by Jscobey »
removed all the PAIR hoses and everything. put on pair block off plates.
Nore Mine :-(
Lloyd your never without a belly pan, just ask Mcdonalds :lol:
I will later :-) ck is buying !!!!
Did various little bits & pieces to the pair of Storms, then hung Drooper from the rafters.
Took a we breather to sort out the neighbours son's YBR125 front brake lever which was sticking on...
Took some bits off Drooper, then took another breather when Jamie ''the Petcock killer of old Alresford Town'' turned up to collect me spare petcock.
Meanwhile back at Drooper... stripped off the rear end to get this off...
Be putting a standar shock & swinger on tomorrow.
The Nitron will be heading Nue Red's way... :thumbup:
chric
Post by chric »
de stickerd wheels washed and waxed bike and a bit of cquartz
and taxed it
