Ted's 'storm resto
Re: Ted's 'storm resto
Agree no Hydraulic tensioners on VTR's. That must some kine of generalised instructions. I don't know as I not read them.
I also agree, no hydraulic tensioners on the Firestorm,
Ted77
Post by Ted77 »
Well, I've fitted them!! Took probably longer than 2.5 hours, but then I did have to clean all the years of cack off too!!
Will post pics when I have wifi and not 3G!!
bigtwinthing
Post by bigtwinthing »
Ted77 wrote:Well, I've fitted them!! Took probably longer than 2.5 hours, but then I did have to clean all the years of cack off too!!
i turned mine over about 200 times before i pressed the start button, i was "cacking" myself. it started a treat, ran lovely and after 7000 miles haven't adjusted it once.
Ted77
Post by Ted77 »
Well, I promised photos, so here they are!
Massive thanks to Carl for his brilliant write up on how to fit CCT's - the daunting task that it seemed to be, was made 100 times easier with his help - thanks fella :-)
Good job well done :thumbup:
:clap: :clap: :clap:
It given you the chance to get in and do some more cleaning too.
http://www.vtr1000.org/phpBB3/viewtopic.php?f=9&t=25177
Ted77
Post by Ted77 »
I did the carbs too, Carl - just forgot to say!! Also put new pads in the calipers.....just waiting for the new rear line to arrive so I can put them all on the bike and do the brake fluid/bleed!
bigtwinthing
Great work Ted, like the red ones!
Ted77
Post by Ted77 »
I did a bit of 'tarting up' this morning...
Couple of other brackets to paint, plus the bottom yoke when I get around to pulling the forks out!
Is the Kitchen in the Garage or Garage in the Kitchen. :lol:
I see you have plastic end cap missing on the front faring bracket/stay. Check you still have the balance weights inside the tubes where the mirrors attach. They help reduce vibrations. :wink:
Ted77
Post by Ted77 »
The garage has my sisters old kitchen units in it as my work bench!
And I just went and checked the bracket - both end caps are there :lol: ...just the photo makes it look like one is missing!!!
Ted77
Post by Ted77 »
And it continued a little today...
And then after checking the head bearings (and finding they're still spot on), I painted the bottom yoke!
And fitted the re-painted side stand...
Next job will be to do fork seals, and clean the front wheel up!
Ted77
Post by Ted77 »
Work got in the way yesterday, but I have just ordered up a set of K-Tech springs to go in the front end when I change the seals/oil over!
Ted77
Post by Ted77 »
Been busy cracking on, so not really been on here all that much.
Rear line fitted:
New springs, oil & seals done:
Old crappy springs:
Fairing bracket painted and back on:
Master cylinder bracket painted:
Fitting things back together:
And what she looks like now!
Just lower fairing to go on, and a bar end to get (if anyone has a spare + bolt, let me know!!) and then an MOT at the end of the week!!
Think it must be time for a beer! :beer:
Cheers for all your help :thumbup:
