stock carb + exhaust +air filter set up
Re: stock carb + exhaust +air filter set up
So what was the verdict on your set up in the last post big sheep lovin' fella?
Mixtures too rich .
I went to 1.5 rear and 1.25 front and it ran well
Hmm... How many turns out on the A/F mixture screws F&R would you go for initially on my setup?
I've got the sheared screw out: Image
Just popped these thumbscrew jobbies in :) :) :)
Start at 2 f and 2.25 r then go in a 1/4 turn till it's just right .
Well done getting it out !!!
Thanks dude I'll try those settings, then have a read on how to get the "blip test" just right.
Just need to sort the valve clearances now :eek
Never done the blip test myself as I like to ride it and feel the difference .
I set my by going in to 3/4 turns out so it lean surges then turn out 1/4 till it stops ,make a note of there position and keep going out 1/4 turn till it rich surges and take a note .
I then set it half way between the two for a base setting . Then I'll go in or out 1/8 till it's crisp
The thumb screws make this easier and more so with the overflow bottle removed :-)
:thumbup: :thumbup:
I'll do that ^ cheers mate.
I do like your HRC baby bottle :)
It's handy for setting the the carbs as it's out the way and once it's set up I'll refit the standard one .
Dyno next month :-)
macdee wrote:
lloydie wrote: I have had 3 sets of carbs but all have been dyno jetted Carl so I don't know standard setting .
8541 hawk has a setup for standard carbs/ needles/ 48 pilots etc/ standard air filter/slip on,s
you need to read it yourself there's loads of info
let us know how you get on :D
Of course you can always ask about that thread right here...... :wink:
Also the "base line" pilot adjustment recommendation is a bit on the rich side. I did that as a lot of folks just do the base line and don't adjust from there so I would rather have them a bit rich than too lean.
I guess it's old habits from the 2 stroke days, hey I even still cover the clutch when riding...... 8O :lol: :lol:
Me too just waiting for the engine to seize :lol:
