Fireblade help!
Re: Fireblade help!
turbo_billy wrote:Have a look here Watty.......
http://www.ebay.co.uk/itm/HONDA-CBR-100 ... 58a26ed14d
Second hand I know but £80 for a pump COMPLETE with tank seems cheap by comparison. :D
Thanks mate, got your pm :thumbup:
midlifekrisis
Re: Fireblade help!
Post by midlifekrisis »
Hi Watty
Is the blade carbed or injected, may of the Hondas have a crank sensor which energises the ecu / module which switches the relay for the fuel pump, it may not be the fuel pump!
It would be worth checking a couple of items before buying anything eg if you put a direct feed to the pump does it work, if it does start tracing back on the 'electrics (I've had a module fail and later a fuel pump) if it is a pump and the bikes carbed, have a look at kiwicomponents.com!
Dave
Re: Fireblade help!
midlifekrisis wrote:Hi Watty
Dave
Thanks mate but as in my previous post, power getting to pump and had a direct feed to pump and it don't play! :(
Re: Fireblade help!
So hit it with a hammer until it does...simples :D
Re: Fireblade help!
Pete.L wrote:So hit it with a hammer until it does...simples :D
:lol: I'm surprised he hasn't! He's a bad tempered bugger 8O
midlifekrisis
Re: Fireblade help!
No worries Watty, you never know! if you need a pump and its carbed I may be able to help! Is it a Mitsubishi pump (there is a cast logo in the plastic end cap) which the points burn out?
You can get a points kit or change the unit for something more reliable.
Dave
Re: Fireblade help!
midlifekrisis wrote:No worries Watty, you never know! if you need a pump and its carbed I may be able to help! Is it a Mitsubishi pump (there is a cast logo in the plastic end cap) which the points burn out?
Dave
Unfortunately its injection mate but he's sourced one. Thanks anyway :D
midlifekrisis
Re: Fireblade help!
Great stuff, summer time starts very shortly, enjoy
Dave
Re: Fireblade help!
Right then! Developments! Party girl and darkember were heading down the right road! It seems my brother indeed did have power to what he thought was the pump feed but he had actually tested and power probed the fuel low warning wire :? The actual cause of the problem was, he had had the key in bits to replace the remote batteries, a small piece of loose plastic fell out!!!!!! he left it out as he thought it was just a broken piece of plastic!!!!!!! But guess what!!!!!!! It was actually the transponder 8O So now he has a running Blade and a spare fuel pump! Every day is a school day :lol: . Thanks again for all your helps :thumbup:
