Throttle position sensor.
Had a nightmare of a job refitting the carbs. Ended up heating, greasing, grunting and groaning to get them on. I loosened the bolts on the surround brackety thing. In doing so I managed to break the TPS. Honda wanted £154 for a new one. Got one for £17 on eBay but broke it when fitting. Exactly the same position. Balls!! Is there a cheaper aftermarket one I could get to fit? None on eBay. Only ones attached to carbs for £60 odd. Also any tips to fit it without breaking it?
Re: Throttle position sensor.
Be gentle when fitting it .
It's only two screws and you need to make sure it's located correctly .
As you've seen they come on carbs and you normally have to buy a set to get one .
Also any tips to fit it without breaking it?[/quote]
Let someone else do it by the look of it
I did exactly the same and managed to get a 2nd hand one on eBay. You just have to make sure it's located and doesn't jump out as you tighten the screws. I had to pay around £20 for the TPS. Some Honda cars use a very similar sensor but I think the arm position would need to be checked. Didn't manage to find a new one at a reasonable price. Good luck with the search.
If you've over-cooked it, just lean it over more.
Let someone else do it by the look of itWatty wrote:Also any tips to fit it without breaking it?
Is that an offer?
Is that an offer?[/quote]anonomoose wrote:Let someone else do it by the look of itWatty wrote:Also any tips to fit it without breaking it?Sounds like thas got a touch like an elephant
Where are you based?
Make sure it has the metal inserts in the bolt holes or you will break them
In the South easy near Eastbourne
Bit far for me to come to assist!anonomoose wrote:In the South easy near Eastbourne
