as anyone got the specs on the spacer and bolt sizes needed to retain the oem rear footpegs whilst using hi level pipes.
iirc it's a 70mm M8 bolt and a 40mm M8 spacer, can anyone confirm this asap please.
hi level footpeg spacers
Re: hi level footpeg spacers
Sounds about right, but you can reduce the spacer a little by relieving the footrest casting to allow the pipes to nestle in a bit.
It helps to get a decent "tucked-in" look at the rear.
Do you want me to measure mine up tomorrow for you?
that would be great kev....Kev L wrote:Do you want me to measure mine up tomorrow for you?
If you find a place to get these, I'm after 2, will even take 4 if you can get your hands on them.
tokens available as usual.
Don't hassle me
I'll get there at some time
Rear footrest spacers for my Scorpion cans are:-
50mm long
20mm Outside diameter
10mm Inside diameter
Bolts are M8 X 90mm long taking measurement from underside of socket head,
50mm long
You could cut this down to the required length (50mm), although if you wanted a polished finish it looks like you would need to do that yourself:-grumpyfrog wrote:If you find a place to get these, I'm after 2, will even take 4 if you can get your hands on them.
http://www.ebay.co.uk/itm/ALUMINIUM-ROU ... 5afff24d3c
I still have the high level spacers fitted to mine with the low exhausts i took one off and the spacer is 52 mm long 20mm wide, 8.5 mm hole , m8 bolt 80mm long 25mm thread the rest plain
