I have a mate racing in the Wirral 100 on the Anglesey circuit over the weekend (pre injection). So will use that trip to see what's what. Cheers guys
I know it will not improve anything at the moment, but it might make it run like crap.
Plan is to see if it runs ok'ish as is. If it's not too bad then I'll start to increase the baffle to lid gap by introducing fibre washers one at a time (either side) in between the mounting screw hole mating faces & trimming a little off the top of the vertical filter dam each time, so the lid still seals as it should.
That way, by me introducing small changes I should see/feel when it starts to misbehave, That's the theory
It might be a total waste of time, but it might not. We will all know by Monday
BTW, IIRC, a little moisture/rain in the intake increases power, so with out even fitting it there's a benefit noted already
