Explanation of How Petrol Tank Breather Works
thunderbolt
Re: Explanation of How Petrol Tank Breather Works
Post by thunderbolt »
My breather hole for reference.
Don
Bikes:
1981 Moto Guzzi 850 T4
1990 Suzuki VX800
2003 Honda Firestorm VTR1000
macdee
Post by macdee »
you have a very nice hole
TravisZack
Post by TravisZack »
Can you not seal the tank as normal and then bore the little hole out afterward if it closes up? Quite a lot of sealant would have to go through the hole, around the ring and down the tube before causing any sort of blockage?
Speaking from absolutely no experience here so maybe that's a naïve outlook.
thunderbolt
TravisZack wrote:Can you not seal the tank as normal and then bore the little hole out afterward if it closes up? Quite a lot of sealant would have to go through the hole, around the ring and down the tube before causing any sort of blockage?
It took a great deal of effort and mucking around to position the dental type mirror to get a picture of the breather hole inside the tank. To be able to bore sealant out of the existing hole if it was needed would be darn near impossible I would think. Can't get much in through the tank filler cap. Maybe a piece of wire the correct size could be bent in a "U" shape though and maneuvered up into the hole would work.
Don
Bikes:
1990 Suzuki VX800
Just put a small wooden plug (half-a-cocktail stick) in it that you can easily remove after coating.
thunderbolt
Wicky wrote:Just put a small wooden plug (half-a-cocktail stick) in it that you can easily remove after coating.
BRILLIANT!! Wicky
Aren't some of the most brilliant ideas the simplest.
Thanks
Don
Bikes:
1990 Suzuki VX800
thunderbolt
macdee wrote:you have a very nice hole
Yes I know . . . :D
Don
Bikes:
1990 Suzuki VX800
popkat
Post by popkat »
thunderbolt wrote:My breather hole for reference.
Why do you want to put Por15 in the tank, it looks mint inside :confused
thunderbolt
There is a leak at the rear of the tank. I thought it was where the rear bracket was welded on. But now I'm thinking it might be the "O" ring that seals the petrol outlet on the '03 models. Early models don't have this setup. They have a different fuel tap arrangement. Waiting for the "O" ring to arrive in the mail.
You are right, the inside of the tank is in mint condition.
Don
Bikes:
1990 Suzuki VX800
Great picture Don. :thumbup:
This was a very much needed thread. Something that has not been covered so much on the forum. Great info on the Phosphoric acid too.
