Hi there,
Could someone tel me the location of the engine oil drain plug
Thanks
Ned
oil drain plug
Re: oil drain plug
On the sump ,near the side stand
Re: oil drain plug
Remember to put it back on !
Re: oil drain plug
Remember to invoke the prayer...
''Our Lord VTR in heaven, CCT be thy name, give us today our daily V twin GRUNT & hallowed be thy Reg/Rec...Please allow my oil to be free of metallic particles & keep the stripped threads at bay. For ever & ever VTR.''
Re: oil drain plug
Or use a spanner.MacV2 wrote:Remember to invoke the prayer...
Re: oil drain plug
Thanks for that,does the drain plug have a compressible washer if so
Do you need to replace it when retrofitting drain plug.
Thanks
Ned
Thanks
Ned
Re: oil drain plug
The Workshop Knowledgebase > VTR1000F (Superhawk) Firestorm Service Manual PDF > http://www.vtr1000.org/phpBB3/viewtopic ... 31&t=18025
Might be an idea to download the searchable Service manual
Sump Fiche > http://www.ronayersmotorcycles.com/fich ... veh=132082
If you're changing the filter then this Oil filter wrench is useful > http://www.ebay.co.uk/itm/OIL-FILTER-RE ... 256eba0446
You can use a new copper washer or reuse the old one by heating it up red hot before quenching it.
[youtube][/youtube]
[youtube][/youtube]
ned58 wrote:Thanks for that,does the drain plug have a compressible washer if so
Thanks
Ned
Re: oil drain plug
Bloody brilliant.Remember to invoke the prayer...
Be careful not to over-tighten the sump plug back up and strip the threads. That would open up a whole can of worms for you. On an old tired threads sometimes the recommended torque is a tad too much. Tightening by feel is good enough on something like this bearing in mind the temperature of the metal (expansion/contraction). I usually drain the oil while hot, plug goes back in the sump when cooled down somewhat.
