They both sheared off while trying to tighten them, luckily at the time, they were in far enough that brake fluid wasn't coming out.
So now I'm trying to get them out and replace them.
They both sheared the little bolt on top, leaving a little hole visible where the oil would normally come from.
I put a screw / stud extractor in the hole and tightened. It got to the point I couldn't tighten any more and it kept slipping in the tool.
I took it out then tried the next size up, that one didn't screw in as far, but sheared in the hole. I've tried drilling the stud remover but it's very very hard and the drills get nowhere.
Now I'm left with this, so, any ideas on how this can now be removed?:
Before:
After:
