Fireblade 1996 front end
Moderator: VTRDark
StormyRob
Post by StormyRob »
I'm posting this here incase someone is interested in the front end.
I do not have one for sale but I did find one.
I asked him how much for yokes brakes and forks and he said £150 which is dirt cheap.
Just posting this in an effort to inform! If the seller turns out to be a tool don't hold me responsible.
Also of this post doesn't fall within rules please delete.
Sent from my E6653 using Tapatalk
Seeker 77
Re: Fireblade 1996 front end
Post by Seeker 77 »
Just messaged him, the price has gone up to £225! Still a bargain for someone
Seeker 77
Post by Seeker 77 »
And the fork seals need doing
StormyRob
Post by StormyRob »
Mate
If you definitely want it and are happy to trust him you can probably have
Forks
Yokes
Clipons
Front fender
£150
StormyRob
Post by StormyRob »
You don't need the wheel discs or calipers mate
Definitely worth 225 though.
Very cheap at that
Seeker 77
Post by Seeker 77 »
Ah ok, didn't know that. I know Yodi from Gixerjunkies days, nearly bought a Gixxer 750 from him a while back. Wanted the wheel and spindle as well though as it looks nice
StormyRob
Post by StormyRob »
Just for clarity folks
While this is still for sale £240 will get you
Clipons
Forks
Yokes
Front fender
Front wheel
Discs
Calipers
He does have quite a bit of interest apparently and I believe him but 240 for the whole front is decent.
Depends on what year it is if you want to use the storms wheel and discs .
94-97 ,other years you will need to find other wheels and disc
StormyRob
Post by StormyRob »
It's 96 lloydie
Mellis can you pm me?
Seeker 77
Post by Seeker 77 »
Does the spindle fit too?
Stephan
Post by Stephan »
mellis wrote:Does the spindle fit too?
Yes, you just need new spacers.
I did this swap. Difference is really small, and if you keep stock internals and springs, it is almost useless. Next stage is to upgrade lower triples for better one, making this setup really up to date. Only advantage is adjustable compression.
Send stock forks to Roger D and you will see what is making the difference.
If I do it again:
1. I would upgrade internals - Roger, or new fully adjutable cartridges from Andreani
2. New CNC triples - my works really well and does the difference
Stephan wrote:Send stock forks to Roger D and you will see what is making the difference.
+ 1 on that.
Another advantage with the blade forks besides compression adjustment is, they are thicker 43mm dia. stanchions against the Storms 41mm, so should be more rigid.
To get the best from either, they need to be reworked for your specifications IE. body weight and style of riding road/race,
Stephan
Post by Stephan »
45 mm, but with the same crappy one bolt steel lower triples :) I think 41 is fine when the rest is sorted.
Stephan wrote:45 mm, but with the same crappy one bolt steel lower triples :) I think 41 is fine when the rest is sorted.
Ah my mistake, that's even better :wink:
I agree with the single bolt on the lower triples, twin bolts much better,
