Ebay Finds (unusal/cheap/rare/or just good value)
Moderator: VTRDark
Re: Ebay Finds (unusal/cheap/rare/or just good value)
lhs mirror on ebay, about as cheap as you'll find....http://www.ebay.co.uk/itm/1998-HONDA-VT ... 3641.l6368
- freeridenick
Anyone got any thoughts on this engine? http://www.ebay.co.uk/itm/182029762208.
Looks like a fair amount of sealant round the flywheel cover, but it still seems like a bargain even with the split mountings. Pretty sure these could be welded up and bingo, spare engine.
Yes, I think you could weld up those engine mounts and they would be fine, but I think you have to assume they removed the engine for the same reason they removed the front cam cover......... CCT failure.
so if that hasn't been fixed then it is already overpriced.
freeridenick wrote:Anyone got any thoughts on this engine? http://www.ebay.co.uk/itm/182029762208.
Need more info on it, cct damage, head damage, crank, pistons, why is it for spares?
- freeridenick
Asked but not got a response yet.AMCQ46 wrote:Yes, I think you could weld up those engine mounts and they would be fine, but I think you have to assume they removed the engine for the same reason they removed the front cam cover......... CCT failure.
At least it still has a clutch cover on it, you'll getting least £70 for that alone.
- bigtwinthing
it worth £100, i would have it if i had a Storm, strip and do up or strip, take the good bits and chuck the rest. i would be very surprised if theres not £100 worth of bits in there.
Let's assume the front head's got two ben inlet valves, as per normal.
You can buy two 2nd hand inlet valves, fit those, reshim, and sell the head for £70.
Clutch cover, another £70.
Rear head, £35-40.
cct's? Nowt, they're standard and at least one's fooked.
Clutch complete- maybe £30
Alternator, for someone to have machined so that their bike's not off the road while the machining's being done? £25
Alternator casing with windings- £35
If there's a starter motor on it, another £40
Starter motor sprag clutch and reduction gears- £20.
Nothing else will sell, so give it to the local scrappy.
OR:
Buy two CCT's and two 2nd hand valves, plus a head gasket, and have a spare runner waiting just in case. Or sell it for £300.
OR: Buy another dead engine and a sheet of glass; make a coffee table.
Rear head, £35-40.
OR:
tony.mon wrote:Let's assume the front head's got two ben inlet valves, as per normal.
Rear head, £35-40.
OR:
its had a grinder through the top engine mounts
- freeridenick
Easily welded. I'm having it if he can wait a couple of weeks for collection. Going on current progress I'll need spare engine parts - everything else I take off to fix results in five other things that need fixing. I fully expecting the engine to junk itself when I finally get it going again.StuartWags wrote:
freeridenick wrote:Easily welded. I'm having it if he can wait a couple of weeks for collection. Going on current progress I'll need spare engine parts - everything else I take off to fix results in five other things that need fixing. I fully expecting the engine to junk itself when I finally get it going again.StuartWags wrote:
worth it in terms of the usable parts.... i did get lucky and get a runner for £70 odd quid once but that was a gamble... in fact still using it
rentec luggage rack and fitting kit, looks like a very good price, doubt it will be for sale for long.....http://www.ebay.co.uk/itm/Honda-VTR-Fir ... 6016.l4276
original undertray, apart from one small drilled hole for an alarm, it has everthing for £16 delivered, that's a real bargain....
http://www.ebay.co.uk/itm/HONDA-VTR1000 ... 1501668274
Best mod for that s to stick it in the bin.
