Link pipe OD measurement
darkember
Post by darkember »
Not being near my bike would anybody know the OD of the link pipe ends for a Scorpion slip-on can system??
VTR Phoenix
Re: Link pipe OD measurement
Post by VTR Phoenix »
Would it be the same for other aftermarket slipons? I have the micron pipes sitting here
Best measure it for your particular system if your sizing it for the replacement clamps - as diameters can differ depending on if gaskets are used or not. I've had to use different sized clamps when either using stock, micron or moriwaki link pipes.
Normally 52mm
darkember
Post by darkember »
lloydie wrote:Normally 52mm
Damn was hoping you were going to say 50.9mm. Still at 52mm SP engineering can sort my links to fit their cans. These guys look like they do a really good job and have has some really encouraging reviews.
http://www.spengineering.co.uk/xjr1300-99-03.html
bigtwinthing
Post by bigtwinthing »
Mine were 51mm.
darkember
Post by darkember »
bigtwinthing wrote:Mine were 51mm.
What exhaust system was fitted??
bigtwinthing
Powertech Performance cans and s/s downpipes with Powertech Link pipes.
darkember
Post by darkember »
51 is doable probably actually 50.9 but i do believe the Scorpion systems are 52 just to be awkward so one cannot slip anything else on
bigtwinthing
yes you can, on flea bay you can buy a 3" long pipe thats 52mm 1 end and 51 the other. I had some for my Bulldog. £24 posted if i remember correctly.
darkember
Post by darkember »
bigtwinthing wrote:yes you can, on flea bay you can buy a 3" long pipe thats 52mm 1 end and 51 the other. I had some for my Bulldog. £24 posted if i remember correctly.
Hunt me that down if you can find it :)
bigtwinthing
i will have a look this w end.
