Hi I am a new member to the owners club and I am currently restoring a 2000 plate with high lift exhausts, but I would like to return it back to almost original, I am after a pair of link pipes for slip on cans and would swap the high lift pipes.
Many thanks guys.
Martin
Welcome Martin to the forum, you should have no dramas finding someone who wants to do that swap! It might be useful to measure the internal diameters of the pipes at the front and rear as that will help someone to work out if they are going to be the right fit for their cans
The diameter of the can end is 51mm outside and header end is standard 48mm outside.
They are in good condition they also come with can holders and footrest spacers.
Martin
martinc wrote:I tried to reply by my email link but unfortunately it would not work because I have to participate a bit more before this function works.
Yep and it's the same to enter the sales and wants section .
Think you need to have a read of the forum rules .
see if you can load some pics up i mite be interested in these. i take it its just the link pipes not the cans you want to change as id be keeping my own cans .
High, here is a picture of what there is, it is the high lift link pipes the footrest spacers and the brackets for the cans, no cans supplied.
What I need is link pipes (X2) that connect to the standard header 48mm that will connect to after market cans 51mm.
