under tank pipe routing
not sure if this is different between the early and late models, the smaller diameter pipe that run into the underside of the tank, I assume it runs towards the front of the bike and exits near the oil filter like a lot of the other pipes. I haven't been able to find any pictures of how's it's routed, can anyone advise.
from the little I know, it runs across the top of the rear cam cover towards the nearside off the bike, so it'll tuck inside the frame, but at which point exactly?
Re: under tank pipe routing
mine runs over the cam cover to the frame then as you say down to the nearside of the oil filter.
Cadbury64
Post by Cadbury64 »
agentpineapple wrote:not sure if this is different between the early and late models, the smaller diameter pipe that run into the underside of the tank, I assume it runs towards the front of the bike and exits near the oil filter like a lot of the other pipes. I haven't been able to find any pictures of how's it's routed, can anyone advise.
RTFM*
* read the freaking manual! Section 1-18
RTFM*
having looked online at different websites and microfiches, I wasn't able to find the info I required, hence asking the question I did. i'd like to thank you for pointing out that the info I wanted was in the manual. although it's on page 1-21 not 1-18. I also didn't much like the way you replied to my humble question. so i'll leave it like this.
WDYFO*
* why don't you f..k off
carmanbikes
Post by carmanbikes »
Hiya AP :wave: is it the pipe that has the reducer on it where it fits on the tank
carmanbikes wrote:Hiya AP :wave: is it the pipe that has the reducer on it where it fits on the tank
yes mate, I had a go this afternoon, but I seem to have a lot of extra pipe left over, so i'm wondering if it works it's way around the engine and back, a kind member has offered to ride down at the weekend so I can see the routing on his bike.... :thumbup:
carmanbikes
Just bee out and checked m8 and mine just runs down the inside the frame and then meets a bundle more which are cable tied together
cheers lee........... :thumbup:
Cadbury64
Post by Cadbury64 »
RTFM*
WDYFO*
You're welcome, I'm glad I was able to point you in the right direction to find the diagram that you needed. Sorry I was three pages out, and that you have taken umbrage at my antipodean humour.
[youtube][/youtube]
NZSpokes
Post by NZSpokes »
I ran mine out by the rear CCT as when it was up the front it filled up with water and stalled the bike. No problems since.
Cadbury64 wrote: You're welcome, I'm glad I was able to point you in the right direction to find the diagram that you needed. Sorry I was three pages out, and that you have taken umbrage at my antipodean humour.
[youtube][/youtube]
sorry fella, I was having a bad day, if you'd attached one of these.... :lol: :wink: :thumbup: I would have laughed it off. but no harm done.
