no spark
buck
no spark
Post by buck »
Was coming home from work the other day and bike just cut out and wouldn't start took out plugs and no spark any pointers please 1997 model
Steve
Re: no spark
buck wrote:Was coming home from work the other day and bike just cut out and wouldn't start took out plugs and no spark any pointers please 1997 model
Steve
If it just cut out when riding could be the R/R has failed. Did the clocks ''die'' before the cut out ? Any other symptoms before death ?
Try jump starting it. Mine started on a jump but then went again after a few miles, the jump only puts so much electrickery in the batt, which soon goes if not being replaced.
When I got it home batt was showing 11. 5 volts, changed the R/R, swapped the batt. fired up first prod, no issues since.
Re: no spark
Does it turn over. Could be a loose battery connection.
