(no longer) Wanted: 30mm Generator Cap - (Part acquired!)
Moderator: VTRDark
Re: Wanted: 30mm Generator Cap
What you actually need is a cheesy allen key, that way, if it's even softer than the plug, then you can't overtighten it. Use a proper one to undo.
Or drill the hex hole round, tap it with a left-handed thread, supply a lefthanded bolt.
When you try to tighten it up, you'd only be able to apply a small amount of tightening torque before the bolt unscrewed.
But the bolt would tighten in as you tried to undo the cap, and it would come out every time.
Simple, but probably too expensive for mass production.
Transaction compleate. Tony paid via PP... :thumbup:
TheGingerBeardMan
Post by TheGingerBeardMan »
Why thank you all. I shall change the post title now. Look forward to getting it. Haven't forgotten about the high temp silicone and the ''finger tight'' only.
Hmm. finger tight only. That reminds me of a lass I went out with years ago....
erm....moving swiftly on.... :silent:
BAD gingerbeardman....Very Bad. :oops: :shifty: :twisted:
TAX: 1st March 2017
MOT: 16th March 2017
INS: 14th March 2017
