Starter clutch needed
Moderator: VTRDark
Stevo Kifaru
Post by Stevo Kifaru »
Starter clutch desperately needed, anyone got a decent one hanging around they'd like to sell me? Preferably as soon as poss!
Re: Starter clutch needed
I have two but they are both attached to engines. How quickly I can get one off depends on how quickly I can get a flywheel holder and puller. I'm in the process of splitting one of the engines already.
Stevo Kifaru
If you get them done soon, I'll have one off you
Stevo Kifaru wrote:If you get them done soon, I'll have one off you
I'll let you know after the weekend. I'll be raiding the old man's garage on Saturday for tools.
I've got about 4 in a box in the garage !
Don't know when I'll get in there tho !
Stevo Kifaru
Seeing as you are in Cov Lloydie that would be perfect, Martin Mellors will be doing the work for me
If you have a 1\2" air impact gun there is no need for a holder and the puller is just a 22X1.5 bolt :thumbup:
Stevo Kifaru wrote:Seeing as you are in Cov Lloydie that would be perfect, Martin Mellors will be doing the work for me
Martin in Radford ?
Stevo Kifaru
Yes, Martin Davenport, the old guy from Mellors. He's in Telfer road/Foster road
I know him ! He works out his garage in the back road .
What is it you need ?
Sprag clutch
Anything else ?
One way bearing ,inner roller bearing ?
Just want to make sure I have the correct part/parts
Stevo Kifaru
lloydie wrote:I know him ! He works out his garage in the back road .
Sprag clutch
Anything else ?
I have no idea to be honest, sprag clutch/one way bearing I think, Martin said they are the usual casualties in a big V twin. We haven't had it apart yet, but as I work nights it's quite important I get this done fast to be honest. Going to still have to try to use the bike as it is until I can get the work done
I'll try and get in there tomorrow if I can and have a rummage
Stevo Kifaru
I'll phone Martin up to check what I need, as luck would have it he had a Virago in with the exact same problem so could show me the starter clutch assembly from that
