Starter clutch needed
Moderator: VTRDark
- Stevo Kifaru
Starter clutch desperately needed, anyone got a decent one hanging around they'd like to sell me? Preferably as soon as poss!
- freeridenick
Re: Starter clutch needed
I have two but they are both attached to engines. How quickly I can get one off depends on how quickly I can get a flywheel holder and puller. I'm in the process of splitting one of the engines already.
- Stevo Kifaru
If you get them done soon, I'll have one off you
- freeridenick
I'll let you know after the weekend. I'll be raiding the old man's garage on Saturday for tools.Stevo Kifaru wrote:If you get them done soon, I'll have one off you
I've got about 4 in a box in the garage !
Don't know when I'll get in there tho !
- Stevo Kifaru
Seeing as you are in Cov Lloydie that would be perfect, Martin Mellors will be doing the work for me
If you have a 1\2" air impact gun there is no need for a holder and the puller is just a 22X1.5 bolt
Martin in Radford ?Stevo Kifaru wrote:Seeing as you are in Cov Lloydie that would be perfect, Martin Mellors will be doing the work for me
- Stevo Kifaru
Yes, Martin Davenport, the old guy from Mellors. He's in Telfer road/Foster road
I know him ! He works out his garage in the back road .
What is it you need ?
Sprag clutch
Anything else ?
One way bearing ,inner roller bearing ?
Sprag clutch
Anything else ?
Just want to make sure I have the correct part/parts
- Stevo Kifaru
I have no idea to be honest, sprag clutch/one way bearing I think, Martin said they are the usual casualties in a big V twin. We haven't had it apart yet, but as I work nights it's quite important I get this done fast to be honest. Going to still have to try to use the bike as it is until I can get the work donelloydie wrote:I know him ! He works out his garage in the back road .
Sprag clutch
Anything else ?
I'll try and get in there tomorrow if I can and have a rummage
- Stevo Kifaru
I'll phone Martin up to check what I need, as luck would have it he had a Virago in with the exact same problem so could show me the starter clutch assembly from that
