Hi guys,
Looking at these:
http://www.ebay.ie/itm/Honda-VTR1000-Fi ... SwY45URmTC
Anyone have them? Good/bad? Any better recommendations?
Thanks!
Ian
Steering bearings
- Ianasauras
Re: Steering bearings
Possibly the best out there TBH, you could probaly but the bearings themselves cheaper but you get the bottom spacer doodah in this kit...Ianasauras wrote:Hi guys,
Looking at these:
Thanks!
Ian
- KermitLeFrog
I fitted these particular ones over the winter. I've done a couple of hundred miles and have readjusted them once. They seem fine but, obviously I have no idea how long they will last.
If you have the original ball bearings (which I did) the difference can be marked. Notchy steering and a hands off wobble have gone.
Ian
Ian
- Ianasauras
Thanks guys,
Yeah notchy steering is definitely something i deal with.
I'm getting my forks looked at this month as i need new oil and there's a 'click' when i brake, dunno what's causing it. Figured it'd be a good time to replace the original bearings.
- KermitLeFrog
Yup. I had that too. Now fixed.Ianasauras wrote: and there's a 'click' when i brake, dunno what's causing it.
The "click" could be the stem moving as you brake due to the bearings being worn.
The tapered bearings don't need to be torqued to the same as the ball bearings. You need to "seat" the bearings first with about 35nm, then slacken off and do up to about 3nm and do the locknut up hand tight and put on the lock washer thingy. Then steering stem nut as normal torque.
Make sure that the set you buy comes with too and bottom seals.
- KermitLeFrog
Another way to seat them is to go for a bumpy ride. Then adjust.
I don't like the way the bottom washer seals tight on the All Balls bearings. I use JMP, they also come with the washer it's a much better fit and the bearings are good quality. All Balls has a catchy name but they are not better than many others out there.
