Romans lend me your ears,again
Re: Romans lend me your ears,again
cheers folks, il just step away from it for a while.. im hoping the rich running is because of the timing being wrong as iv had the carbs of and checked them a few times and cant see anything amiss with them or any of the pipes...
ok started from scratch ,front cyl set to. ft, rear cyl spun round the 3/4 it needed. cams wre all over the place. no idea what stroke they were on but pulled them out, fitted them as per the mcct thread. checked anything else i could like carbs and wiring and fired it up. first hit of the button and ticking over way better than it was, even sounded better so out for a we scoot.
no lumpy running just felt like a different bike
... right up to 5.5k and the humpy blue b8stard is still the same.. refuses to rev through it and i held the fuker to see if it would....
![Big Grin :biggrin](./images/smilies/biggrin.gif)
![Thinking :think:](./images/smilies/icon_think.gif)
Simple thing to check...The petcock diaphragm for splits...then the carb diaphragm for splits or pin holes...fabiostar wrote:ok started from scratch ,front cyl set to. ft, rear cyl spun round the 1 turn and a quarter needed. cams wre all over the place. no idea what stroke they were on but pulled them out, fitted them as per the mcct thread. checked anything else i could like carbs and wiring and fired it up. first hit of the button and ticking over way better than it was, even sounded better so out for a we scoot.
no lumpy running just felt like a different bike... right up to 5.5k and the humpy blue b8stard is still the same.. refuses to rev through it and i held the fuker to see if it would....
Also just a thought when you took it out for a run 1st time & run out of fule you may have pulled some crap out of the tank & into the carbs...be worth checking your fuel filter in the tank they can be a git to get out tho...
im gona check the diaphram in the tank and change ecu from the red bike and rule those out, frustrating as im so close..
failing that im gona take mind altering drugs and slump in a corner crying..![Beer Popcorn :Beer Popcorn:](./images/smilies/Beer%20Popcorn.gif)
Based on the line highlighted above, he has put the timing to 180 deg out!!!!! if you start at the front cyl, you gou ACW by 3/4 turn to get the correct RT mark........... But I spoke to Rob already and he is sure he only did 3/4 turn... its just he cant type!!!fabiostar wrote:ok started from scratch ,front cyl set to. ft, rear cyl spun round the 1 turn and a quarter needed. cams wre all over the place. no idea what stroke they were on but pulled them out, fitted them as per the mcct thread. checked anything else i could like carbs and wiring and fired it up. first hit of the button and ticking over way better than it was, even sounded better so out for a we scoot.
I think we need to put him on suicide watch
YYYYEEEEEEHHHHHHHHHHOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO got it sorted...
for sale, one ECU....
. changed the ECU from the yellow bike and away it went... thank the lord himself iv won. iv also learnt more about bikes in the last few days than the last 10 years.......
major beer time
![beer :beer:](./images/smilies/beer.gif)
![Confused :confused](./images/smilies/confused.gif)
major beer time
lol cheers Al.... one problem masking the other but all sorted.....
oh i feeeeeeeeeeeeel gooooooooooooood today..
Good stuff Rob........ Now you know how 4t works
TIP; Never take a sleeping pill and laxative on the same night
http://morrisonbhp.net/
- alanfjones1411
Good news Rob. Go and have a beer or two mow
Have you been for a good run and does she rev past 5.5k. How's your fuelling?
Someone is going to have a good weekend now ![](https://emoji.tapatalk-cdn.com/emoji106.png)
![](https://emoji.tapatalk-cdn.com/emoji16.png)
![](https://emoji.tapatalk-cdn.com/emoji898.png)
![](https://emoji.tapatalk-cdn.com/emoji322.png)
![](https://emoji.tapatalk-cdn.com/emoji482.png)
a bloody great weekend..lloydie wrote:Someone is going to have a good weekend now
ay its revving the very best. still running rich low down but il sort that easy enough but not now, for now i just want to gear up on sunday and bring it out for a chilled out thrash.....
Really good newsfabiostar wrote:YYYYEEEEEEHHHHHHHHHHOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO got it sorted...
for sale, one ECU..... changed the ECU from the yellow bike and away it went... thank the lord himself iv won. iv also learnt more about bikes in the last few days than the last 10 years.......
major beer time![]()
i lokked at that timing so many times i got myself in a tiz esp when it was fixed it still ran crap so ended up questioning myself had i really fixed it, but having the ecu play up at the same time was masking anything i was doing with the cam timing..sirch345 wrote:Really good newsfabiostar wrote:YYYYEEEEEEHHHHHHHHHHOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO got it sorted...
As I said in your other thread, I'm glad you got to the bottom of the problem
great advice on here so beers on me lads..
