Just a few questions, wonder if anyone can help answer them:
1) How hot/cold do these bikes run on the gauge?
This one seems to run a little under half when out on open roads, but it warms up quite quickly if you are crawling around town, enough so to put the fan on (you only have one fan too, right?).
2) Front forks super soft?
I remember reading somewhere (here or elsewhere) that the front forks are rather soft, wasn't aware you can run through virtually all their travel under hard braking though. I'm 85ish kgs, I'll add in the last two 'rings' of preload but I'm pretty sure I might need some new springs. Would linear rate be better if its only me on the bike (no pillion/luggage). Rear suspension seems little too hard too, hmmm.
3) Is there a restriction in one of the exhaust silencers?
When warming the bike up some vapour comes out the exhausts but gradually this disappears from one before the other (left before right). When looking at aftermarket exhausts someone (can't remember where, I really should take notes) said that there is some form of 'cone' restrictor in one of silencers that he noticed when modifyng the stock cans. Is that true, or a load of twaddle?
4) Soft limiter at 10,300 rpm?
I've missed a couple of shifts
5) Tyre pressures?
Handbook and Haynes both state 36psi front and 42psi rear, I shouldn't need to fiddle with these?
6) VTR 'V' model?
I see in Haynes (and online) reference to different models of VTR. I've seen a chart with registration dates with V being a 1997 model. Is that all the V would stand for, nothing special about it? Any idea then why a V model VTR would have a marginally lower recommended idle speed 1,100 (+/- 100) as opposed to all other models with 1,200 (+/- 100)?
7) Size of hex for crankshaft end cap?
I need to remove the crankshaft end cap when doing the tensioners but can't seem to find reference to the proper size. Biggest I have is 6mm, looks like 8mm maybe?
Thanks
![Smile :plainsmile](./images/smilies/smile.gif)
