Thanks for the complements guys!
freeridenick wrote: ↑Fri Dec 02, 2022 2:22 pm
That looks great and an equally good photo. I'm assuming it wasn't taken with a phone. Given the depth of field and framing I'm guessing you like a bit of photography as well as bike building. If it was with a phone then it's a damn good one.
its my iPhone 11 pro... I do like a bit of photography... A few years ago I sold all my SLR gear though, as after a holiday I looked at my wifes photos off her phone and thought why am I carrying this big lump of a camera around! I was playing on my sons iPhone 14 last weekend, and the camera is another leap forward and I have phone envy now
So its start-up time… I had a good spark, but I wasn’t sure if it was on the right cylinder as I hadn’t made a note on the coils… so it was a 50% chance it would start… It did! It quickly settled to a nice tick over, but I had to shut it down as I am missing the “0” rings off the sensors and they leaked oil. I have been waiting a week for them, bloody Royal Mail strikes!
With any fresh engine build I have a routine I stick to that has served me well over the years… first thing I do is remove the oil switch and pump oil into the engine. I use a plastic pump up bottle for this. This primes all the oilways, fills the filter, fills the oil pump, and oozes out of all the bearings. I prefer this to engine building paste, which I am not a fan of… I do use a smear of it on the cams and followers though…
The other thing I do is screw in a pressure gauge. I was pleased to see that it immediately shot up, which is always a relief. This has saved me a couple of times in the past… Once when the pressure relief valve in a new oil pump was stuck, and the gauge went off the scale… the other time was my fault when I put an oil pickup pipe joint on wrong, and the joint itself covered the pipe hole… started it up and initial pressure then nothing… that gauge is a lifesaver!
![Image](https://jtccc.files.wordpress.com/2022/12/startup-copy.jpg)
