The other thing the powder coater did for me was the plating… but he didn’t, despite having it a month. I used to do this myself with a home kit, but it was hugely time consuming and he would do a batch for £45. I knew this had potential to hold me up again so after the bank holiday I made a list of local companies that did plating. The first one I visited said I would need to open an account… and the minimum invoice was £120… The second one, the reception was locked, so I wondered into the factory via a side door to be met with a very friendly guy, the owner of the company. I showed him what I had and he said he would do it… but they had a minimum charge… £28! He said come back next day as he would do it at the end of today’s production run. Next day I popped back… Fantastic job!
I hate hammering bearings in where there is an alternative… so I pull the head bearings into place with a large piece of threaded bar, this works a treat and allows the bearings to be seated nicely before assembling the headstock.
One job I needed to do was to check that there was no blasting media in the frame oil tank. Although I had sealed it you never know, that blast media has a habit of getting inside! I used my bore scope which is an excellent bit of kit! It has an 8mm camera probe and LED lights, it plugs directly into my phone so I can see inside things like engines, it takes stills and videos! All for £15! No sign of any media at all.
As I was doing it my wife came into the garage with a coffee… I said let me have a look in your ear… I checked inside her ear and said “just as I expected…nothing in there” she silently walked out… with my coffee
It’s all coming together fast now as you can see…
