So, I have fitted 2 manual tensioners.
The front one had failed before I bought the bike and I knew it had to be fixed.
I needed 2 exhaust valve too but all that is done. I followed the manual tensioner installation guide, a great help by the way, but the cam chains seem a little rattly when the bike is running. Is there a way to adjust them safely without taking the cam covers off or is it best to part strip it again and re-adjust a little tighter?
Manual tensioner adjustment
Re: Manual tensioner adjustment
Warm the bike up. Then tighten each tensioner until the tapping noise "just about" disappears. It will still rattle for a minute or two from cold as it warms up but will not be too tight when hot.
