Anti
sammy347
Anti
Post by sammy347 »
Just wanted to ask if anyone here ever used milk of magnesia on exhaust manifold studs. I'm putting on a split flange and going to use ss bolts. I was just reading about mm on another forum seems it's even used in jet fighters as an anti seize. Cheers
Re: Anti
Hahahaha MM No...
50/50 ATF* & Acetone. Works wonders...
Give them a good soak over a week with a fresh dob daily. Use a decent stud extractor & give it a wee nip up to break the corrosion bond...
*Automatic Transmission Fluid... ATF
haynesjones66
Re: Anti
Post by haynesjones66 »
dont know if i should, but i put copper grease on a lot of my fixings
sammy347
Re: Anti
Post by sammy347 »
So no one has tried I will be be the first to experiment so
Re: Anti
sammy347 wrote: Mon Aug 26, 2024 12:40 pm So no one has tried I will be be the first to experiment so
It will interesting to hear first hand from you if it does work as an anti-seize agent?
Re: Anti
do it and report back, its mad stuff like this that sometimes works :thumbup:
sammy347
Re: Anti
Post by sammy347 »
Sure will no harm in trying
sammy347
Re: Anti
Post by sammy347 »
sammy347
Re: Anti
Post by sammy347 »
