Hi first post
I got get my written of vtr 1000
Home with flat rear tire pushing
It going try pump it up
I have qwestion how use a padlock
Stand with no spools on swingarm
Don't think can fit them
As my stand got square tube
Extensions it just slide off.
Newbie bike stand qweston
Re: Newbie bike stand qweston
You need a set of these that will fit your new stand, make sure the size is correct, although one would hope they are standard.
Not sure where you are in the world, but this is what’s needed or similar: https://www.ebay.co.uk/p/7030273481?iid=314217848609
PS. It looks like you could be in New Zealand.
PPS. Welcome aboard
PPS. Welcome aboard
You can fit bobbins...
Some have had a block welded on to the bottom, drilled & tapped.
Some have used Rivinuts into the swingarm & screwed in the bobbins.
Some have just drilled the swingarm & tapped the hole to size & fitted.
Some use a threaded bar through the spindle with bobbins on the end...Ok for chain lube/adjustment but you cant remove the wheel with this type.
Finally if you can find or make some adapters/hooks that go on the spindle...Again Ok for chain lube/adjustment but you cant remove the wheel with this type.
Or as Chris said get some replacement cups for your stand.
- KermitLeFrog
ABBA stands are great. Bur, I got one of these the other day https://www.constands-power.com/en/ and they are wonderful as well. Fidddly to set up but being able to wheel the bike around with both wheels off the ground is super helpful.MacV2 wrote: ↑Wed Nov 06, 2024 4:53 pm Or better still invest in an ABBA stand...
https://abbastands.co.uk/?gad_source=1& ... gJtrPD_BwE
That's me I drilled and tapped the holes 25mm up from the bottom of the swingarm and 107mm in from the backend. Swingarm thickness is approximately 4mm thick. I used bobbins with 8mm diameter thread bolts, fine thread is best,MacV2 wrote: ↑Wed Nov 06, 2024 4:51 pm You can fit bobbins...
Thanks so much everyone
Very helpful yes in new Zealand.
Me, too. They even put up with sitting in the bike while it's on the stand, so plenty strong enough. +1 for the M8 fine thread.sirch345 wrote: ↑Wed Nov 06, 2024 9:24 pmThat's me I drilled and tapped the holes 25mm up from the bottom of the swingarm and 107mm in from the backend. Swingarm thickness is approximately 4mm thick. I used bobbins with 8mm diameter thread bolts, fine thread is best,MacV2 wrote: ↑Wed Nov 06, 2024 4:51 pm You can fit bobbins...
