Romans lend me your ears,again
Re: Romans lend me your ears,again
i had a read of that link to tonys post, if its out just turn the rear 1 full turn then put the cams back in....?
sounds simple... :Banned: :Banned:
It is simple, but like I said give the valve clearances a quick check as it's easy to under or overtighten the cam caps down which affects the clearance. Oh...and go easy on them cam cap bolts as they can snap easily especially if old stretched bolts and you do up to the specified torque in the manual. I like to do them up slightly under.
just confusses me as everything lines up.
And this is why it often gets missed. There's two TDC's so make sure your on the compression stroke.
macdee
Post by macdee »
When are you going to attack this
And as dark says it's worth checking the chokes
Just to make sure there not slightly open
il take afew days to think about what to do cause im kinda burnt out bikewise atm..
right so plan is. check the engines not out, if it is. going by what iv read. remove the rear cams, and turn the engine one full turn back onto the RT mark.. :thumbup:
What have the Romans ever done for us ?
They made ccts? and wore skirts
fabiostar wrote:They made ccts? and wore skirts
And straight roads !!!
geoff996
Post by geoff996 »
MacV2 wrote:What have the Romans ever done for us ?
The A5
RIDE TO ENJOY
they also made me wombles my engine...i knew i shouldnt have went near it but it sounded simple..
rear cyl onto comp with RT lined up. with lobes pointing up and inwards.
remove cams.
turn engine one full turn until RT returns to line up at the crank..
one full turn didnt get no RT or anything else to line up .
question is were the fuk am i now?
hallie
Post by hallie »
Drop it down to me for a month or two :lol:
TIP; Never take a sleeping pill and laxative on the same night
http://morrisonbhp.net/
hallie wrote:Drop it down to me for a month or two :lol:
throw it down you mean..... fuk only knows now were my timing is .completly lost so for now its got the cover over it before i do anymore damage to something.
ok so gave it some thought. im assume i missed the rt mark first time round. so spin it again and it came up... back to were i started ?
so went round another full turn and got the rt mark this time... now am i missing something but iv set the rear cam in. but theres no way i can see of getting the front cam in place. theres just not enough slack in the camchain?....
i just remembered why i hate fuking 4 strokes :eek2
Have you removed the cct ?
lloydie wrote:Have you removed the cct ?
oh fuk me pink dont tell me that has to come out???? :biggrin im at the stage now iv no idea what piston is on what stroke anyhow..... nything i read, and iv read myself stupid on the subject i didnt see any mention of taking the cct out?....
