WORKSHOP DAY.
slipper 1
Re: WORKSHOP DAY.
Post by slipper 1 »
Shame I will miss this as I am working overseas at the mo. How often do these happen? Just ordered CCT's from ROAS, and need someone to advise/help on fitting. the bike is still on automatic tensioners, but has quite a backfire on the over run, and I am a bit concerned that maybe the timing is already out.
bazza696
Re: WORKSHOP DAY.
Post by bazza696 »
They backfire for a number of reasons, mine was doing it becuase of a leak at one of the exhaust joins, or running rich or lean.
I swear mine backfires in the shed even when not switch on.
Re: WORKSHOP DAY.
We also have two bikes being fitted with manual CCT's, and both needing valve clearances checked.
So lots to watch and hopefully learn from.
See you Sat!
Tony
Darknomad
Re: WORKSHOP DAY.
Post by Darknomad »
woohoo i have dust caps oils caps upper and lower bushes and now a hyperpro progressive spring kit im good as ready for saturday
will by manual cct at tones gaff will look at peoples braided brakes mods see whats involved
i booked friday of to do prep stuff if need be i can possibly do some shopping if people need stuff from halfords u can square up at tones likes tools fluids
i dunno what ever
east london/essex [leyton ]
Re: WORKSHOP DAY.
Got yourself some fork oil?
Darknomad
Re: WORKSHOP DAY.
Post by Darknomad »
yup and some stickers and a teeny pot of grease gunk all part of the spring kit :D 7.5 1 litre
tinysmall
Re: WORKSHOP DAY.
Post by tinysmall »
Is there still enough room for one more bod? I need to do my CCT's.
alec
Re: WORKSHOP DAY.
Post by alec »
can someone pm me Tony's address please, i have pm'd him but doesn't seem to be about tonight and i deleted itby mistake, must be watching comic relief lol
Re: WORKSHOP DAY.
PM coming :thumbup: your way mate
alec
Re: WORKSHOP DAY.
Post by alec »
Kev L wrote:PM coming :thumbup: your way mate
thanks Kev
Darknomad
Re: WORKSHOP DAY.
Post by Darknomad »
Im sure theirs space for more
Just cut n paste ure work plans
So it can be organized
tinysmall
Re: WORKSHOP DAY.
Post by tinysmall »
Bazza696 (the Man for CCT's- some spare modified manual ones will be available on the day)
Jonesy (the Man for BRAKES. Any and all aspects thereof, full caliper strips etc.) Be glad to help.
Darknomad- manual ccts fitted and timed, carb balance, forks if i get springs, and valve shims if im lucky on the day to have right shims from a local shop or Tony .Mon
Alec- carb balancing & QA throttle mod (i have a pot from a 35mm film) just a general check over if poss please.i'll fit carb balancer take-offs without removing carbs (small hands!)
Elric - Making sure Yeti is working to the right specifications and tolerances.
Robwestwick
Parkergb6
Blob748
Yeti Tea making (wait 'til you see the hi-tech kettle!)
Styler4077
Wicky (front pot carb balance insert inserting - small hands required)
Matinik46
Macv2 -just joining in, and watching
Tinysmall-CCT's... was coming, then wasn't, now am again :D
Ummm... what time is it kicking off?
Darknomad
Re: WORKSHOP DAY.
Post by Darknomad »
kicks off ten ish
careful of local roads
can be loose stones etc in centre
tinysmall
WORKSHOP DAY.
Post by tinysmall »
Ya muchly :thumbup:
alec
Re: WORKSHOP DAY.
Post by alec »
tinysmall wrote:Bazza696 (the Man for CCT's- some spare modified manual ones will be available on the day)
Robwestwick
Parkergb6
Blob748
Styler4077
Matinik46
10 am mate
