brake line kits.
lumpyv
brake line kits.
Post by lumpyv »
if i were to change my old brake lines for spangly new braided ones do i want a 2 line kit or a 3 line kit? both the ones , from the same manufacturer, that i have looked at say "buy these to replace standard"
?? cheers
Re: brake line kits.
two separate for the front and a single for the rear
and one for the clutch :lol:
lumpyv
Post by lumpyv »
aha ! well ive had a bit more of a look and the three line kit is standard and a 2 line kit is an "over the mudguard " set ?? i dont think either include the rear brake/clutch though?? :confused
you dont really need the rear as it dont get used as hard as the front .
and the clutch gives better feel when it grabs
for the front just get the kit with to long pipes not the over mud guard kit
you will also need 4 p clips to keep them tidy
lumpyv
Post by lumpyv »
cheers mate :thumbup:
Also go for stainless steel or the cheaper zinc plated fittings, but not anodised alloy for road use :!:
templ8
Post by templ8 »
Try a Venhill kit if you can.
I fitted Goodridge brake lines and struggled getting the lines on without twisting, the ends are crimped on and hard to rotate for a good fit.
Got a Venhill clutch line and its far superior, the banjo fittings are threaded so the line screws on to them, dead easy to get a good fit. They have chromed fittings instead of cadmium plated so should stay nice for longer too
lumpyv
Post by lumpyv »
templ8 wrote:Try a Venhill kit if you can.
these were the brand i was looking at..
Lloydie you got fleas again mate?
brake line kits.
Yep I've got an itch waiting for parts to come tomorrow :)
seb421
Post by seb421 »
Get HELL Lines ive had Venhill in the past they was good too
lumpyv
Post by lumpyv »
just had a look at whats on the bike and from the brake lever it goes to a splitter then to each caliper so guess what i need is a 3 line kit?.
lumpyv wrote:just had a look at whats on the bike and from the brake lever it goes to a splitter then to each caliper so guess what i need is a 3 line kit?.
You don't have to go that way, you can just run two hoses from the M/C, one to either caliper. That's the set up on mine and it works fine.
if you want some fancy lines, i go with hel, they have lots of colours........ :thumbup:
http://h-e-l.co.uk/
