heat shrink tubeing
seb421
heat shrink tubeing
Post by seb421 »
i want to use heat shrink tube on the coils after doing the coil mod, i just need to get a solder before i can finish off
what tube size diameter will i need to join the CBR's to the VTR's i want to run it the full length from the plug at one end to the plug at the other
thanks
also will a hair drier work or will i need a heat gun
Re: heat shrink tubeing
Halford's do a little box full of various sizes.
Using short lengths will let you slide a larger diameter over a smaller diameter and then heat it, you'll get a better seal form larger to smaller wires that way.
If using a larger diameter sleeve to shrink onto two pieces of wire, squeeze a tiny bit of silicon sealer inside before shrinking it; this keeps water out and the joint can't corrode over time.
Maplins do packets of heat shrink in 1mtr lengths for reasonable money Seb.
Nice tip regarding silicone there Tony. :thumbup:
SMITH MEISTER
Post by SMITH MEISTER »
You can also get glue lined heat shrink. :wink:
WOW that's a new one on me! Nice one SMITH MEISTER. :thumbup:
