Help! - Access to timing marks
mr.john.coates
Post by mr.john.coates »
Right, I've started my CCT work but I can't move the central cap to gain access to the end of the crankshaft.
I've soaked it in WD40, put an extra long extension bar on the allen key (actually an 3/8 drive Allen socket) but all this does is chew up the metal.
Before there were no flats left I've had an impact driver on it for about 1/2 hour, hitting as hard as I dare. I've tried gentle heat from boiling water - don't want to get blowlamp on it - and I've tried tightening it a bit to break the threads.
My only thought now is a proper impact wrench - but I don't have one :(
Any other ideas?
Thanks, J
NT650V in Red
VTR1000R in Blue
Pushbike in Yellow
Wife in Bed
Martyjuk
Re: Help! - Access to timing marks
Post by Martyjuk »
Undo all the bolts and remove the complete generator cover.
alternative_vtr
Post by alternative_vtr »
Try soaking in WD40 then have a go. Or as said remove whole cover. If your stuck for tools or anything I am not far from you (near Derby) :wink:
KTM Duke 690ABS in White
mr.john.coates
Success !!! :D
I followed Tony's advice and drilled 4 x 5mm holes around the edge of the cap to give purchase to a punch and drifted it round. It was very tight and clearly never been off before. I hope all the fasteners aren't like this, I don't like big hammers around my bike. Had to give it much welly !
Thanks for the advice and thanks esp to alternative_vtr for offer of assistance and tools.
Now on with the rest of it...
Mr.J
NT650V in Red
VTR1000R in Blue
Pushbike in Yellow
Wife in Bed
alternative_vtr
Sometimes just going away and coming back to it helps :wink: glad you got it done.
alternative_vtr wrote:Sometimes just going away and coming back to it helps :wink: glad you got it done.
No, it won't undo by itself while your back's turned.
Going away and coming back with a bigger hammer helps, though.
:lol:
Xenocide
Post by Xenocide »
I've had round one with mine. Not got started on round two yet. Going to need a bigger hammer I think.
I'll probably drill two holes in it around the edge then use a bicycle cassette cage removal tool thing to try and take it off, or just a bit of metal with two small bolts in it.
'98 VTR (Red - the quickest)
'94 KTM LC4 400e
'69 Land Rover S2 Lightweight
Try an angle grinder centre nut key, they have two rods sticking out; if you drill the holes in the right places......
Xenocide
Post by Xenocide »
I thought that but I lost my key thing years ago :(
'94 KTM LC4 400e
