Exhaust Question?
VTRPiG
Exhaust Question?
Post by VTRPiG »
Hi guys in the process of making up some exhaust hangers to smoothen out the rear end. Question is- Is it necessary for the link pipes to be bolted to the rearsets? Reason I ask is i can re position the silencers to a higher position, pointing up towards the rear of the tail section and tampering inwards like on the SP1/SP2's. When i twist the pipes the little piece that is welded onto the link pipes is no longer in line with the rearsets to bolt into place.
Cheers in advance
Pig
2003 VTR1000
SP1 forks
Fireblade Rims
In the best colour ..... RED!
Re: Exhaust Question?
i removed the brackets from my link pipes to raise the cans .
i had no adverse problems from doing it and i had less vibrations through the pegs
here a pic of mine when i did it .
No, the can is still held where it clamps to the header pipe and the hanging bracket just supports it. :thumbup:
VTRPiG
Post by VTRPiG »
Cheers guys thank you very much, will be cutting them nubbin things off then tomorrow :D
Will post pics once done :thumbup:
2003 VTR1000
SP1 forks
Fireblade Rims
Agreed, not necessary; some aftermarket link pipes don't have the brackets anyway.
But it makes it important to have decent brackets for the cans.
If you place the bracket too near the engine end, the can is unsupported for most of its length and can vibrate. Worse, it can fracture at the collector joint or can end cap/link pipe joint.
