Failing cct???
Failing cct???
Hi guys, opinions needed if you could please. My recently aquired storm has a bit of a clatter when coming down the revs on the overrun at about 1500rpm and sometimes on tick-over if you tickle the throttle. This only happens when the motors hot and done a few miles. What do you think,,,,,failing cct???
Re: Failing cct???
Milage? and when were the valve clearances last measured?
Usually CCT fail without warning, so get them attended to pronto > See the workshop knowledge base sub forum for how to fit manuals or how to do the failsafe stopper mod.
Re: Failing cct???
could it already have had the stopper mod done and it's failed???
Re: Failing cct???
The bikes done 22,000 miles and i have no idea if the valves have ever even been checked. The ccts look to be original and don't appear to have any kind of mods done to them.
Re: Failing cct???
I have just put a manual cct on mine because it had a horrible clank on the front cylinder and it's fixed it completely. I think CCT's must be able to just weaken off as normal ones do as well as fail completely.
Re: Failing cct???
If they have not been changed then do them as a matter or urgency as a precaution. You can check your valve clearance at the same time. But at that sort of mileage I doubt they need adjusting but should have been checked at the 16,000 service interval.
Re: Failing cct???
Thanks for all your comments, looks like i have a few things to do then!
