Damit!!
VTRPiG
Damit!!
Post by VTRPiG »
Ok failed at the first hurdle :( got the bike mounted on the abba stand no worries and used some wood to raise it a little. Got the wheel off now worries but the caliper won't come off the disc! It has worn away and there is an edge on the outer rim of the caliper that the pads get caught on when you try to lift it off. :eek2
Was hoping to not have to bleed the caliper but am I gonna have to to get it off or is there another way?
2003 VTR1000
SP1 forks
Fireblade Rims
In the best colour ..... RED!
Miztaziggy
Re: Damit!!
Post by Miztaziggy »
Is it front or rear wheel?
If the pads are getting caught, just push them in. Get a screw driver and lever it against something solid to force the pads away from the disc. It should push back fairly easily, certainly enough to give you a few mil clearance to get the caliper off the disc.
Re: Damit!!
Lever the pads back which pushes the piston in. You should be able to lift the calliper and pads off then. Note the little metal spring clip that that sits towards the front of the bike against the pads and the calliper mounting bracket. Best to remove the brake calliper before taking the axle bolt out the rear wheel though, otherwise you will struggle with positioning the wheel and getting the calliper off at the same time.
Re: Damit!!
Just remember to clean the piston before you go pushing it anywhere or you can push dirt into the seals and cause yourself more issues. :thumbup:
Re: Damit!!
8541Hawk wrote:Just remember to clean the piston before you go pushing it anywhere or you can push dirt into the seals and cause yourself more issues. :thumbup:
An old toothbrush and some brake cleaner (not toothpaste) works well.
Re: Damit!!
As an altenative to pushing the pistons back in...
Whip out the pad pin & the pads will drop out.
Calliper lifts off as the pads are not catching on the lip.
When you have it off..(frnerr frnerr) then clean the pistons & push back in ready for when you want to put it back together.
Re: Damit!!
A handy tool for pushing back pesky pistons.
http://www.ebay.co.uk/itm/US-PRO-BRAKE- ... 3a8293cb26
Check your disk/s are still within wear limit tolerances
darkember
Re: Damit!!
Post by darkember »
Wicky wrote:A handy tool for pushing back pesky pistons.
Your calipers should not be worn, it will be the disks
