2nd gear
vtrnewboy
2nd gear
Post by vtrnewboy »
do all vrt's suffer from a clunky second gear , never jumps out of gear just a clunk when you go into 2nd my two mates have vtr's and theirs also does it :(
Re: 2nd gear
Never really noticed anything distinctive. Changing oil can sometimes help smooth things out.
vtrnewboy
Re: 2nd gear
Post by vtrnewboy »
Wicky wrote:Never really noticed anything distinctive. Changing oil can sometimes help smooth things out.
1st thing I did new oil and filter , just all 3 of your bikes do the same :(
Re: 2nd gear
A quick search shows this > http://www.vtr1000.org/phpBB3/viewtopic.php?f=7&t=123 & http://www.vtr1000.org/phpBB3/viewtopic.php?f=9&t=717 but little else from over a decade.
You must be still running in :wink:
ebenviljoen
Re: 2nd gear
Post by ebenviljoen »
vtrnewboy wrote:do all vrt's suffer from a clunky second gear , never jumps out of gear just a clunk when you go into 2nd my two mates have vtr's and theirs also does it :(
my bike has 13k on the clock, full service history, I just put new very expensive oil and filter in, and still have a clunk. its not massive, but not as silent as all of the other gears for instance. I have seen this question asked a few times and the normal answer is, yes. :thumbup:
chric
Re: 2nd gear
Post by chric »
Yes you know its a honda when it clunks :thumbup:
Bananaman
Re: 2nd gear
Post by Bananaman »
i had exactly the same on my 97 vfr, if it dont klunk going into second, it aint a Honda! :thumbup:
Four wheels move the body,
Two wheels move the soul.
ging500
Re: 2nd gear
Post by ging500 »
Try riding the bike differently!! Ie short shift into second, give the throttle a blip. The Honda cbf600 clonks if you rag it in first.
Re: 2nd gear
Yep clunk 1st-2nd all the Hondas I've had gave done it and the vtr is a little worse as its gear box is from a tractor lol
darkember
Re: 2nd gear
Post by darkember »
Quite normal get used to it or buy a Suzuki :D
Re: 2nd gear
2nd gear is always going to be a bit tricky for the box as it has to get past neutral. Try to be a little smoother with the gear changes helps. You could also move 1 spline to the right on the selector shaft which gives it a shorter shift and adjust the gear lever to suit. But yes they all clunk a bit so perfectly normal.
Re: 2nd gear
The crush drive rubbers and gear linkages play a big part in the smoothness of gear changes
Re: 2nd gear
ging500 wrote:Try riding the bike differently!! Ie short shift into second,
+ 1 that's what I would suggest, changing into 2nd gear as soon as possible without revving the bike any more than what is needed.
Re: 2nd gear
Adjust the chain properly, then bleed the clutch for at least half an hour until all the bubbles are out.
If all else fails try fitting a shorted gear lever.
If that doesn't work, split the cases and replace the selector forks, and file undercuts on the engagement dogs.
Good enough for the drag strip, that lot....
kenmoore
Re: 2nd gear
Post by kenmoore »
Short shift and make sure chain is adjusted properly.
I know when I need to adjust the chain by the clunk into second gear.
Adjust and alls well again!!!!! :beer:
South Coast
New South Wales
Australia
