Stripped Starter Motor. Brains required?
After finally getting around to stripping down a Firestorm starter motor, to replace the rusted live (+) terminal nut and bolt for one, I was also looking for a fault that had caused this starter motor not to work properly. Well it seems the insulator that sits inside the starter motor, that the terminal bolt goes through was the problem [see pictures below to show which part I mean (courtesy of firestorm996)], as it was in bits and some of it was even missing. There's also what looks like arcing on the inside of the starter motor body which shouldn't be there if the insulator was doing it's job. If that's was it is (arcing), that would explain why the engine was struggling to spin over, some of the power from the battery when you went to start the bike would have been going directly to earth.
Before I go scratching my head too much, had anyone come up with away to make something up to replace this insulator part :?: as it doesn't look like you can buy this part on it's own. I imagine it would have to be something that withstands heat to a degree, otherwise I could make one in wood :lol:
Cheers,
Re: Stripped Starter Motor. Brains required?
My spare was the same too and unable to hold the bolt central and away from the outer shell .
Maybe one made out of nylon
I'd better get one of those 3D model making machines then :lol:
It seems a shame to have to scrap it just for an insulator,
I smashed mine up the wall trying to get it back together !
What about using plastex to make one .
Is ali conductive ? Shouldn't be to hard to make one in ali
macdee
Post by macdee »
what about using a piece of ikea chopping board
if you do it right the missus won't notice the board is about an inch shorter :thumbup:
a friend of mine is an auto spark i will ask what the material is an see if he has any large spare bits lying around
Carve it out nylon as suggested.
Or splash out on a Hornet starter motor for £20 which is a direct fit
http://www.ebay.co.uk/itm/2003-Honda-CB ... 2a2ce109db
http://www.ebay.co.uk/itm/Honda-CB600F- ... 2575ab418c
or starter motor repair kit (£30)
http://www.ebay.co.uk/itm/Ricks-Motorsp ... 4d0e07f851
darkember
Post by darkember »
Most of the Blade starters will fit as well.
lloydie wrote:I smashed mine up the wall trying to get it back together !
I have no idea if plastex would be suitable, but an idea for sure :thumbup:
Aluminium must be conductive to a degree I would have thought, but that would have been great if it wasn't.
macdee wrote:what about using a piece of ikea chopping board
:lol: I like the chopping board idea, although I doubt the missus would not notice if a bit was missing :lol: Years ago I believe we had one of those white hard plastic things. We shouldn't have thrown it away :problem:
If you can have a word with your friend about this that would be great :thumbup:
Wicky wrote:Carve it out nylon as suggested.
or starter motor rebuild kit (£70)
Thanks for all the info Wicky, excellent :thumbup: That nylon idea has got me thinking :thumbup:
Hardly worth spending a fortune on going by those prices for a Hornet s/motor, especially as it was only going to be a spare on stand by just in case.
darkember wrote:Most of the Blade starters will fit as well.
Cheers for that info as well :thumbup:
Thanks guys, as usual you have certainly given me some more options, brilliant :clap:
macdee
Post by macdee »
sirch can you give some ball park sizes of the piece in question
in other words what size of rectangle is needed to start with before shaping :thumbup:
macdee wrote:sirch can you give some ball park sizes of the piece in question
I would need a piece of material for shaping in this size:-
30mm width
12mm height
8mm depth
Macdee, if you see you friend in passing great please do run it by him, but don't go out of your way to do this, as I may have a suitable piece of white nylon that I can work with.
Thanks,
playerone
Post by playerone »
Ali is most definitely conductive, it's used widely as the cores on high voltage power cables, certainly on railway anyway :thumbup:
Tweety
Post by Tweety »
The IKEA cutting boards are perfect material for that... I use them for a bunch of things, like making end-caps on LiPO4 battery packs... Cheaper than buying it from a company stocking Nylon as material...
macdee
Post by macdee »
Tweety wrote:The IKEA cutting boards are perfect material for that... I use them for a bunch of things, like making end-caps on LiPO4 battery packs... Cheaper than buying it from a company stocking Nylon as material...
thread hijack
tweety i think i seen a post from yourself on the superhawk forum about the lipo4 battery pack would you care to share with the men on here :thumbup:
end of hijack people go about your business
lumpyv
Post by lumpyv »
playerone wrote:Ali is most definitely conductive, it's used widely as the cores on high voltage power cables, certainly on railway anyway :thumbup:
and telephone cables.
I didn't think it was as on a ali framed bike everything needs it's own earth unlike on a steel framed bike .
Learn something new every day :-)
