found this on the trade part of NGK, may have them fitted in your pride and joy
http://ngkntk.co.uk/wp-content/uploads/ ... Hi-Res.pdf
NGK race plug recall
Re: NGK race plug recall
Thanks Chaz, good to know. Mine are DPR9EIX-9 5545 Irridium, not affected thus far.
Hot erosion of the centre electrode will not cause any damage, really, it just makes the bike misfire, nothing to worry about.
Not our heat range or type anyway.
It effectively retards the ignition,as the spark has to propagate for longer before it can jump the larger gap.
Probably.
Probably.
They are probably thinking heating and running hotter or colder than they should so covering their backs.Hot erosion of the centre electrode will not cause any damage
I was expecting centre electrodes dropping into the cylinder....cybercarl wrote:They are probably thinking heating and running hotter or colder than they should so covering their backs.Hot erosion of the centre electrode will not cause any damage
- Pete.L
SP2 is the 6588 so no problem there
Me too. At least they only have to worry about getting a rep for poor quality control. Imagine the damage if the center electrods had been dropping outtony.mon wrote:I was expecting centre electrodes dropping into the cylinder....
It's only an engine; I have others......and the other cylinder was completely undamaged.
