But while I was out yesterday I had a massive slapper (tank slapper that is not the female kind
Basically it just caught me out a bit, I was going out of a 30 zone on to a derestricted stretch and as nothing was coming I decided to overtake the car in frontt who was still doing 30, this put me on the wrong side of the road and I’d given it a bit of gas so the front wheel was just skimming the road, which generally wouldn’t be a problem.Kev L wrote:What have you done with the suspension Budd? Is it riding high at the rear and low at the front? The Storm as stock is a very stable old beastie, so i'm surprised you provoked it into a slapper.
There are a few firms that make them for the storm including some cheapie ones from China. I can't comment on the success of any of them as I haven't got one on mine. Good luck with it fella
yeah I think it's normal, but the lines/ridges in the road really set it off into a quite impressive tank slapper, it's probably a one off because apart from the ‘light’ feeling you mention it’s pretty benign and as you say not generally an issueadyf wrote:My old storm was planted ,but hard on the gas at about 120 front went really light,as in skimming the road,worrying at first then it used to make me laugh in my helmet,never felt dangerous just lively.
then take it off and give it to meAMCQ46 wrote:get the front springs sorted ASAP, 6mm at the back with stock front end is going to make it a bit slappy.
i have an old style sprint damper fitted, but run it on min settings and in truth I only fitted it as I had it in my store cupboard, i don't need
only if you let me look after your header pipes for you…..real waste having them hiding in the garagelloydie wrote:then take it off and give it to meAMCQ46 wrote:get the front springs sorted ASAP, 6mm at the back with stock front end is going to make it a bit slappy.
lloydie wrote:I do have a standard set I could swap with you as you didn't specify what headers
springs are definitely on my 'to do ' listAMCQ46 wrote:get the front springs sorted ASAP, 6mm at the back with stock front end is going to make it a bit slappy.
