Head bearings advice
pstormer
Post by pstormer »
Hi all. Removed the forks to paint the lowers and found the head bearings are goosed :roll: . Quick search on the bay and a full set of taper bearings with seals are on the way :D . As I haven't done a set in a while I would appreciated any advice on how to get the right tightness so as not to over tighten them or have them to loose :? .
Paul
Paul
Steve6088
Re: Head bearings advice
Post by Steve6088 »
From my experience recently, I found that mine kept coming loose. I solved this by making sure the top yoke nut was torqued up correctly.
There is a thread in the knowledge base section which I wrote, it takes you through the correct setting.
Steve, I have to Say mine never come loose after first setting and I think it is down to the races not being hammered fully home hence they move slightly after assembly
Steve6088
Post by Steve6088 »
okay, your probably right.
Jscobey
Post by Jscobey »
when i did my fork swap and put in all balls taperd bearings, for a few weeks they kept coming loose and id get slop in the bearings. i finally fixed it by adding preload to the bearings (having a friend push down on the front of the bike while i torqued the nut to the proper spec)
plus i think it took a few weeks to have the races really seat themselves properly due installing the races with improper tools.
That's not uncommon when fitting tapered bearings. It takes a couple of 100 miles to get them seated and bedded in. So expect to be making slight tweaks to the adjustment first off.
pstormer
Post by pstormer »
Thanks chaps for all the advice :D . Great write up amcq46 :thumbup:
Paul
gabi81
Post by gabi81 »
i plan on doing mine but...dont have the stand to take front end of safely ....ideas??
Aha you know what it is black and yellow...black and yellow !!!
gabi81 wrote:i plan on doing mine but...dont have the stand to take front end of safely ....ideas??
rear paddock stand and use a car jack under the sump. make sure the stand is as far back as it can go for stability, and put some weight on the pillion seat
rear paddock stand
And a little stool !
gabi81
Post by gabi81 »
That's it!!!
thank you
You constipated again then. :lol:
Or abba stand and something under the sump. I use a few bricks.
No the I have the runny kind at the mo !!
That's it this thread is turning to sh1t now :roll:
darkember
Post by darkember »
Lloydie I told you to stop messing with the poodle :lol:
