yamaha r1 voltage regulator
n1tbj
Post by n1tbj »
has any one know of any problems fitting a yamaha r1 rectifier to a firestorme 97 as mine was over charging pumping out 15v and making bike breakdown been told these can be fitted with a bit of mod i know a bit bigger but you dont here or yamahas packing up with this fault
Re: yamaha r1 voltage regulator
Is it a Mosfet version (FH) or a conventional (SH) one?
http://www.superhawkforum.com/forums/kn ... how-25117/
R1 / R6 will need rewiring as the plugs are different.
Check the part number if it starts SH its the older type same as the storm just finned.
They are better than the standard ones in the respect that they dissipate the heat better but they can still fail.
Honda ones off various different bikes are finned a bit smaller but plug straight in...still be SH though so still prone to fail.
Best to get a Mosfet type one. These will deff still need a rewire to the Storm loom. Always have part number starting FH & will have two plugs on them.
Do a bit of research Mosfet & Shingden (?)
Make sure that any connectors you use are big enough and good quality, and solder rather than crimp, unless you have good crimps....
n1tbj
Post by n1tbj »
all done bike now pumping out 14v and running sweet only time will tell want to say thanks to beast /cyber beast for link he posted :clap:
