6 mm spacer
6 mm spacer
I know this thread has come up over and over but I didn't get my answer after searching so here it goes
After the install of the spacer would I need to modify the air gap in front? I have ohlins springs and no idea of air gap...and would it be somehow dangerous to run as it is with spacer added?
Aha you know what it is black and yellow...black and yellow !!!
Re: 6 mm spacer
Feck knows . I run mine 20mm more air gap but I have 929 forks
Re: 6 mm spacer
You don't need to alter the air gap, you may need to adjust the preload to get to around 25mm static sag. you also imo don't need a 6mm spacer, a 3mm or maybe 4mm will be enough.
Re: 6 mm spacer
Not dangerous as it's not that extreme a change. But I agree with popkat that 6mm may be a bit too much. I went back to 3mm as recommended by Roger. I have also dropped the forks 5mm. By dropping the forks by lifting the stanchions up threw the yokes. You can do one side at a time without jacking the front up.and would it be somehow dangerous to run as it is with spacer added?
It's a trial and error kinda of thing, try it and see. If you don't like it then adjust again one way or the other and find what's comfortable for you, but don't go no more than 6mm at the rear or 10mm at the front otherwise handling may become....I don't want to use the word dangerous, but more unstable is a better term.
Re: 6 mm spacer
I would say the same, try 3mm first,
Re: 6 mm spacer
Will try with 6 mm
And go down if too much but with me being tall and banged some weight on think I should be ok
)) in case of a spill I mean
Re: 6 mm spacer
iv a 6mm spacer and a washer in mine. it steers like a gocart and flaps about a wee bit but its great for tipping round sharp turns. and shall we say interesting on faster stuff
i should add my forks are 5mm up through the yokes tho im not and never have been happy with firestorm forks.. gggrrrrrrr
Re: 6 mm spacer
Ok so my next question...
How do I fit it as I tried and I'm not able to lift back end up to slot washer in...
I was thinking of a jack between swingarm and top frame would that work?
Re: 6 mm spacer
Loosen the top shock mount nut. Not all the way, juts enough for the threaded part to drop through a bit. Then get a mate to tip the bike over onto it's sidestand and you should be able to slot the spacer in place.
Re: 6 mm spacer
Aha ...will do thank you
Re: 6 mm spacer
Get a helper... Seat off, loosen the top shock nut but do not remove !!! One of you stands on the left hand side of bike (you may feel more comfy being the lifter as it's your bike of course...), side stand down. Lean over & grab the right hand clip on pull in to full right lock. With your right foot butted up against the stand lean over & grab the subframe & pull the bike up... It will pivot on the stand & raise the rear wheel off the floor. once you get it up it will balance & the weight is not a factor, however you want it done quick as the fear is the stand giving way. It's a tried & tested method BTW. I fitted my spacer this way & on several occasions have done this when having an MOT so the tester can check the rear wheel bearings...gabi81 wrote:Ok so my next question...
The weight should make the wheel drop down allowing the now loose shock to drop far enough to slot in the spacer. Open end to the rear...
Obviously its the spare person either you or the helper to slot it in ASAP.
Once the spacer is in lower the bike back down onto it's wheel, then you can tighten up the shock nut...Job done...Simples..
Re: 6 mm spacer
Yeah what he said but with more detail...
Re: 6 mm spacer
Well it's about time you started pulling your weight.
Re: 6 mm spacer
spacer went on sunday and took it out for a short blast that ended up a long one
i must say it transformed it making it a lot sharper in bends and fun to ride
best 4 pound ive spent so far
Re: 6 mm spacer
Waste of £4 really when you could have made your own for nothing...gabi81 wrote:spacer went on sunday and took it out for a short blast that ended up a long one![]()
