Changing Engine Casing, Gasket Required?
Demonic69
Post by Demonic69 »
Hi All
My engine casing has a hole in it that someone's bodged with liquid metal or something.
I've got a replacement but I need to know if I'll need a new gasket? I've for the part code - 11394-MBT-010 - but it's £30 delivered!! That seems to be about the best price too.
So will I need one and does anyone know of a cheaper supplier?
Re: Changing Engine Casing, Gasket Required?
yes you'll probably need a new gasket when taking off the cover as it'll likely adhere to the mating surfaces and need scraping off.
When replacing you can use http://delta-adhesives.co.uk/products/i ... oncertina/ liquid multi-gasket on one side of the new gasket and grease on the other - so if you can anytime in the future easily take it off again. Also have you thought about putting on a Carbonadi engine cover?
https://www.davidsilverspares.co.uk/par ... 394MBT010/
when you fit the new gasket, put a thin smear of grease on one side of the joint and when you take the case off in the future the gasket will stick to the other side only and wont rip as you remove it........ allowing easy reuse :D
Demonic69
Post by Demonic69 »
Cheers guys, I'll get one ordered and await the black eye from our lass :-)
Sent from my E6653 using Tapatalk
Wemoto have perfectly good ones less than eight quid.
All years are the same.
Demonic69
Post by Demonic69 »
tony.mon wrote:Wemoto have perfectly good ones less than eight quid.
You're a bloody star! I was to focussed on looking for the part number. Cheers very much!
£30 :Shock1: WTF that is an outrageous price.
Demonic69
Post by Demonic69 »
£10.92 delivered from Wemoto, bargain!
