can anyone tell me the correct length of the pin with the allen key head
item number 12
http://www.ronayers.com/oemparts/a/hon/ ... ke-caliper
front brake caliper pin question
- agentpineapple
Re: front brake caliper pin question
http://www.partzilla.com/parts/detail/h ... 0wod7JIFlAagentpineapple wrote:can anyone tell me the correct length of the pin with the allen key head
item number 12
Check the image to the left, pin next to a mesure...looks like it's inches but easy enough to convert...
Found this one as well...It's Ti to boot...
- agentpineapple
cheers mac, it's for a friends bike, the pin on the rhs caliper is chewed up. going to be a b stard to remove, I might have to remove the caliper and cut it out.
Ok firstly try hamering in an oversize torx bit that may get the bastid moving...agentpineapple wrote:cheers mac, it's for a friends bike, the pin on the rhs caliper is chewed up. going to be a b stard to remove, I might have to remove the caliper and cut it out.
Failing that take em off & split the callipers, the pads & spring will fall out of the way, clamp the pin in a vice & turn the body to unscrew it the pin is fubar so you can clamp it up as hard as poss, clout the calliper with a rubber or hide mallet to get it moving...
I bought some titanium pins and had them coated with DLC to free up movement and prevent them from wearing; not cheap, but so far so good....
