TYRES AND PRESSURES
spam
TYRES AND PRESSURES
Post by spam »
Hi all just got a 1997 VTR :thumbup: no manaul could you give the tyre pressures also need new tyres for road use only, what do you suggest? Any idea what a garage would charge to remove and paint rear sub frame.I am in Bridport Dorset. :) Bike is more comfortable than I expected handles well, but need to get the head bearings checked. Thanks
Re: TYRES AND PRESSURES
First of all,hello and welcome to the forum :thumbup: :wave: .36 front and 42 rear.As for tyres i have Pirelli Diablo's on mine.Tyres are a personal choice, but mine suit me for how i use the bike.
I use Michelin pilot road 2,3 or 4
I tend to run them a bit softer than the book states, but the settings above should be your starting point.
As for the subframe , it's a bit of a fiddle as you need to remove a fair amount of the wiring and electrics, so a shop might charge a fair bit for labour. If you are in Devon then popkat may be able to quote you for the job as he runs a shop down that corner of the world
popkat
Post by popkat »
The problem with painting the subframe is you need the paint to be fully cured before re fitting, as to put it back on is likely to scratch the fresh paint if it not gone hard.. So although it doesn't take too long to remove, prep and paint it would need time before putting it back on, which takes a while longer than removing it.
I'm in North Devon, from Bridport I would think it'll be too far for you to leave the bike with me while it gets done and the paint fully cures.
popkat wrote:The problem with painting the subframe is you need the paint to be fully cured before re fitting, as to put it back on is likely to scratch the fresh paint if it not gone hard.. So although it doesn't take too long to remove, prep and paint it would need time before putting it back on, which takes a while longer than removing it.
Buy a 2nd hand one, clean, prep, paint. Leave to cure in your own time...The swap it over when ready...
Clean, prep, paint & cure the old one. sell it to cover costs...
Tyre wise i always run softer than stated in the manual. 34f and 36r suits me..
Saintsman27
Post by Saintsman27 »
Hi M8tey .. I fitted Pirelli Diablos to my VTR... but I found that the
Storm squared off the rear tyre noticeably ,, a great super grip but
really a little wear there ... so I changed to Pirelli Angel St ... sports touring
rear tyre and... tis the dogs " b ....s " so to speak ... little wear.. super feel , impressive
I still have my Diablo on the FW .... I suppose I am too mean to change it.. har :thumbup:
:wave:
If you need a subframe I have two spare to choose from.
spam
Post by spam »
thanks for the advice guys :thumbup:
